Wood Veneer On Melamine - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-03-2013, 08:22 AM   #1
Question
wood veneer on melamine
I am thinking of refinishing the kitchen cabinets in the house I am buying, they are white melamine and about30 years old. I am under a budget restraint and thought of covering them with wood veneer, applied with contact cement. Can this be done
Herb D is offline   Reply With Quote
Old 03-03-2013, 08:36 AM   #2
Bill Kearney
Rewards Points: 1,174
Why not just remove the existing melamine? Trying to get the new stuff to stick on top of the old might be a waste of time. That and by the time you did get it done you'd probably end up with something that didn't look all that great. Price out what replacement doors alone might cost. It may well be a better bargain than what you'll waste on the glue, veneer, edging and your time.
wkearney99 is offline   Reply With Quote
Old 03-03-2013, 08:42 AM   #3
Rewards Points: 14,306
My money goes there's nothing but partical board under it and the melamines not coming off without distroying what's under it.
Old 03-03-2013, 08:59 AM   #4
Bill Kearney
Good point Joe. With today's stuff it'd very likely be a processed product underneath. 30 year old might be even worse. I'd still think it would be a better plan to seriously compare the price of some replacement doors. At least then you're starting fresh and saving a LOT of time.
Old 03-03-2013, 09:03 AM   #5
I agree 100%.
Old 03-03-2013, 02:49 PM   #6
Rewards Points: 936
Sand the mellamine with 100 grit paper. This is for the cement to stick to, otherwise, cement may slide around. Cement on the veneer. Wait until cement is dry enough that most of tack is gone. Feeling the tack means the cement is not dry enough. Put the veneer on and roll. Watch the edge with the roll so you don't roll past the edge and snap off the veneer. You need to roll the edge, making sure the veneer edge has full contact.
After the veneer is on, wait a week without trimming. The first try I did, I trimmed the veneer right away and veneer shrank. Trimming can be done with sharp razor.
carpdad is offline   Reply With Quote
ICF vs. Wood Framed JackOfAllTrades Building & Construction 31 11-01-2011 03:14 PM
Sister joist, replace wood bean, what wood grain? jpcada Building & Construction 14 04-13-2010 07:46 AM
flooring frankiedog Flooring 7 12-05-2008 01:05 PM
DAP caulking question n0c7 Painting 16 10-31-2008 11:31 PM
Wood close to Non-IC recessed lighting-solution? sjmonty Electrical 4 12-01-2006 09:14 AM
