Wood Type For Small Built-in - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-02-2014, 07:44 PM   #1
Trucon01's Avatar
Rewards Points: 510
Wood type for small built-in
Hi All,
I have an opening which is about 18x48 and wanted to build some small shelves.
I havn't decided on how I will finish (stain vs paint), but I'm looking for the type of wood for either.
I was thinking maybe a 1/2 pine if I paint and maybe a cherry / walnut if I stain. Thoughts / suggestions?
Basement Demo started Jan 2012: View my basement progression!!!
Bathroom demo started Feb 2013: View my bathroom progression!!!
Trucon01 is offline   Reply With Quote
Old 02-04-2014, 10:32 AM   #2
Are you planning on some built-in shelves? How deep is the opening?
I just finished a house where the (HVAC) whole-house return took up the bottom half of a chase. The space would have been a linen closet if the return was placed elsewhere. I added shelves, framed and cased the opening and built a frame and panel door to make it a "closet". The opening was about the same as yours. Since the rest of the doors and woodwork in that hallway were painted, I did the same.
For wood type, select white pine or poplar paints up very nicely.
SawDusty is offline   Reply With Quote
Old 02-04-2014, 10:56 AM   #3
Trucon01's Avatar
Rewards Points: 510
Its about 14 inches deep. I was also reading that MDF or sanding down plywood would be an option too.
Thoughts about those?
Old 02-04-2014, 11:12 AM   #4
DIY staff
Rewards Points: 7,174
Cabinet grade plywood with edge banding or a decorative solid wood edge is the most frequently use product for shelving and cabinet work.
Solid wood is great to work with---but the cost will surprise you---If you want real solid wood,find a hardwood lumber store---what is available at the Home Depot is over priced and very limited---
Old 02-04-2014, 11:39 AM   #5
I agree with the comment about hardwood. If you plan to paint the work, I'd go with the alternatives; plywood (with a solid wood edge), MDF, or select white pine. I generally aviod anything expensive if I am going to paint a project.
If you want to use plywood, Home Depot sells a Sandeply that finishes up nicely. Strips of pine would make a good looking lip or band. If there will be any end grain showing, you can smooth it up with sandpaper and then wood filler before you paint. You can sand this plywood but keep in mind that the skin if about 1/64" thick and easy to sand right through. I'd hand sand with 180 grit.
If you use MDF, it does not hold fasteners very well. There are specialty screws for MDF... and do pre-drill holes for the screws. This stuff takes paint and looks good.
Maybe you could post a photo when you get the job done. I'd love to see how it turns out.
The Following User Says Thank You to SawDusty For This Useful Post:
oh'mike (02-04-2014)
Old 02-04-2014, 12:01 PM   #6
Trucon01's Avatar
Rewards Points: 510
I certainly will. Thank you for all your help guys. Would this be OK to use as well?
http://www.homedepot.com/p/Project-P...4153/203504316
*EDIT*
I assume I can use a 16/18ga finish/brad nailer for this project, if I go with the plywood?
Old 02-04-2014, 12:08 PM   #7
Short answer: yes.
Your link took me to birch plywood. I've used Home Depot's birch ply to make some bookshelves. The material worked and finished very nicely... but then is it furniture-grade. Cut carefully as you can get some tearout. You probably already know this, but as a reminder... if you cut with a circular saw, the good face should be down; on a table saw, the good face should be up. You can use a stain and clear-coat finish on this stuff.
Old 02-04-2014, 12:12 PM   #8
Trucon01's Avatar
Rewards Points: 510
Short answer: yes.
Very cool!! Maybe I'll buy an extra piece and stain and clear coat just to see how it looks before I make up my mind.
Thanks again all!
Not to p!mp my thread, but I will be posting the pictures of this project in my basement thread from my signature.
Old 02-04-2014, 03:08 PM   #9
Rewards Points: 3,751
I second the birch. I would use 3/4" and not the half.
I actually did a built in a rock wall facade in our kitchen for cook books. Initially I chose birch to paint because the builder told me the mason was a messy rascal. He wasn't so I got to stain them instead. The birch takes stain well and of course there is always paint.
Colbyt is offline   Reply With Quote
Old 02-04-2014, 03:23 PM   #10
I'm not sure 3/4" is required for strength on a shelf that's only 14" X 18"... but It's a good idea for aesthetics. A thicker shelf will just plain look better.
Here's a place you can go to calculate what thickness really is required. The web page http://www.woodbin.com/calcs/sagulator.htm has a calculator for sag based on shelf size and load weight.
Old 02-05-2014, 09:01 PM   #11
Trucon01's Avatar
Rewards Points: 510
Here she is. Now just deciding whether to paint it white or stain it with the dark red (on right)...
Wood type for small built-in-photo-4.jpg   Wood type for small built-in-photo-5.jpg
Old 02-05-2014, 09:08 PM   #12
Rewards Points: 268
Don't forget your level on the column
packer_rich is offline   Reply With Quote
Old 02-06-2014, 08:34 AM   #13
Trucon01's Avatar
Rewards Points: 510
I'm not ready to drywall yet, but thanks for noticing!
If I decide to stain the wood and do not like it, can I go over it with some Zinsser BIN and then go over with any type of paint?
Old 02-06-2014, 10:08 AM   #14
I do like that stain on the right. Yes, if you try stain and then change to paint, you can cover the stain with BIN or Kilz. If you test the stain and it seems splotchy, it could be the wood. Softwoods and some hardwoods, like cherry, can be difficult, but you can use a sealer / stain control first and then apply the stain. Sometimes a gel stain works better on difficult wood. I generally prefer stain but you do have to experiment a bit with some samples of the chosen wood to get the look you want.
Old 02-06-2014, 11:04 AM   #15
Trucon01's Avatar
Rewards Points: 510
Awesome. I think I will stain the whole thing tonight and see how it goes. One other thing, lets say I stain and then put a few coats of poly on, do I need to sand off the poly before BIN or can I go over that too?
what wood type ? Fix'n it General DIY Discussions 29 01-07-2013 09:21 PM
Type of wood for exterior window frame Mark Harvey Carpentry 4 07-04-2012 09:37 PM
Best type of wood for studs? Leoskee Building & Construction 5 07-26-2009 08:59 PM
Which type of wood is best for a privacy fence? ozarksjim Landscaping & Lawn Care 1 11-14-2008 02:38 PM
Comment on those Special Type of Treated Wood for Deck ? KUIPORNG Landscaping & Lawn Care 4 07-04-2006 01:38 PM
