Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 04-23-2008, 05:31 PM   #1
Wood trims in Bathroom, wood or non-wood
I'm finishing my basement... and in the bathroom, I'm planning on installing a 60'x40' drop in tub. I want to touch up the bathroom with wood trims, such as wainscotting... much like I've seen in some magazine. With the exception of a short tile surround, the tub will be surrounded with wainscotting and wood trims.
I'm worried about having wood material in the bathroom, especially with all the wainscotting I plan on installing.
Do you recommend finding a non-wood product wainscotting? if so, what products out there can you recommend?
dbbyleo is offline   Reply With Quote
Old 04-23-2008, 07:06 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
If you plan on installing alot of wood directly adjacent to a drop-in tub, you could look at Koma Board (Composite material - non wood).
Link: http://www.komatrimboards.com/compan...centerbead.htm
As far as trimwork in a bathroom, unless you have young children or plan on splashing around alot yourself, such wood trim work, is generally well protected with several good coats of paint.
- Build Well -
Old 05-03-2008, 11:16 AM   #3
Expert Hammerer
I agree with AtlanticWBConst.
I have used quite a bit of wood in bathrooms and have never had a problem (when used with a semi-gloss paint). Originally, I had the same concern as you and ordered a composite blinds for a window in a bathroom. However, I put real wood blinds on a large window directly above a bathtub a few years ago and do not have any moisture damage.
The size of the bathroom is also a factor. Steam and humidity can disperse better in larger bathrooms.
Last edited by INeedMoreTape; 05-03-2008 at 11:23 AM. Reason: Added additional information
INeedMoreTape is offline   Reply With Quote
Old 05-05-2008, 11:47 AM   #4
Thanks for looking at this. I appreciate your sharing of your experience. I think I'll go ahead and just go with wood like you said.
Brick and wood flooring jhughesfam Flooring 1 08-18-2007 04:29 PM
wood floors in bathroom? elementx440 Flooring 3 02-17-2007 04:43 PM
Wood close to Non-IC recessed lighting-solution? sjmonty Electrical 4 12-01-2006 10:14 AM
