-   -   Wood trims in Bathroom, wood or non-wood (http://www.diychatroom.com/f14/wood-trims-bathroom-wood-non-wood-20258/)
dbbyleo 04-23-2008 05:31 PM
I'm finishing my basement... and in the bathroom, I'm planning on installing a 60'x40' drop in tub. I want to touch up the bathroom with wood trims, such as wainscotting... much like I've seen in some magazine. With the exception of a short tile surround, the tub will be surrounded with wainscotting and wood trims.
I'm worried about having wood material in the bathroom, especially with all the wainscotting I plan on installing.
Do you recommend finding a non-wood product wainscotting? if so, what products out there can you recommend?
AtlanticWBConst. 04-23-2008 07:06 PM
If you plan on installing alot of wood directly adjacent to a drop-in tub, you could look at Koma Board (Composite material - non wood).
Link: http://www.komatrimboards.com/compan...centerbead.htm
As far as trimwork in a bathroom, unless you have young children or plan on splashing around alot yourself, such wood trim work, is generally well protected with several good coats of paint.
INeedMoreTape 05-03-2008 11:16 AM
I agree with AtlanticWBConst.
I have used quite a bit of wood in bathrooms and have never had a problem (when used with a semi-gloss paint). Originally, I had the same concern as you and ordered a composite blinds for a window in a bathroom. However, I put real wood blinds on a large window directly above a bathtub a few years ago and do not have any moisture damage.
The size of the bathroom is also a factor. Steam and humidity can disperse better in larger bathrooms.
dbbyleo 05-05-2008 11:47 AM
Thanks for looking at this. I appreciate your sharing of your experience. I think I'll go ahead and just go with wood like you said.
