Wood Threshold Replace - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-17-2013, 07:13 PM   #1
wood threshold replace
I have a wood threshold ext. door, need to replace rotten, on the outside there is grout n tile that butts up against threshold outside, inside is wood flooring, its sandwiched in there, is there away to put new threshold in without removing grout or tile,, do the side jambs sit on top of threshold, I think so, whats the easiest solution,the grout line is like 3/4'' wide x 1/2'' thick I think
mh761 is offline   Reply With Quote
Old 05-17-2013, 07:17 PM   #2
Rewards Points: 12,802
Need to post a picture of what you have.
Most thresholds are attached from the bottom up.
mh761 (05-17-2013)
Old 05-17-2013, 07:32 PM   #3
thanks I don't have digital camera yet
Old 05-17-2013, 07:52 PM   #4
DIY staff
Rewards Points: 7,174
What is the door made of? If it's wood--then yes the old thresh can be removed-(
you might want a multi-tool or saws all---cut out as much as you can--the remaining parts need a sharp chisle and a hammer---
then cut a filler out of PVc boars or plastic deck board----when that's flat to the exterior tile--
Carefully fit a new aluminum adjustable thresh hold to fit---
then trim the door----with the cut slightly beveled to give you a good seal.
It came be done---but the job is fairly advanced work---so plan on using your brain a lot---
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
Duckweather (05-17-2013), mh761 (05-17-2013)
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
replace wood railing balusters jad Remodeling 2 04-01-2009 12:24 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 10:14 AM
Threshold problem from bedroom to patio Not Sure Carpentry 11 11-07-2006 08:16 PM
