Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 10-27-2009, 11:27 PM   #1
yoy
Default Wood Stain is a primer also?
I am totally a newbie.
Is a wood stain also a wood primer?
Do I need to prime the wood first and then put the wood stain?
yoy is offline   Reply With Quote
Old 10-28-2009, 01:14 AM   #2
A stain is like a dye, it is used to change or enhance to color of the wood. Depending on the type of wood you sometimes need to use a stain controller first to prevent blotching. If you are staining you generally don't use a primer because you are going to use a clear finish after staining.
hayewe farm is offline   Reply With Quote
Old 10-28-2009, 07:44 AM   #3
The normal process is to first stain then use a sealer (AKA primer) then the top coats. With softer woods like pine you also need to use a pre-conditioner prior to the stain to avoid uneven staining as someone has just posted. but stain itself is not a sealer or primer and has nothing to do with the need for sealing the wood.
Old 10-28-2009, 09:15 AM   #4
gravity always wins
Some stains, Minwax in particular, also contain a sealer.
Old 10-28-2009, 09:16 AM   #5
gravity always wins
Some stains, Minwax in particular, contain a sealer.
Old 10-28-2009, 10:46 AM   #6
skipping the proper steps will only yield a poor job. But MinWax stains is at the bottom of the barrel, so maybe some do not care about quality.
More On This Topic
Hi, this is Jon on behalf of Expert Village. In this video clip we will be staining our project. Before staining my project I went ahead and removed my paint trays and that chain that holds it from spreading out too far. The reason I did this is I don't... Read More »
Hi this is Jon on behalf of Expert Village, in this video clip I will be showing you how to work with wood putty. If we take a look at our trim piece we would notice that there is a small gap where our trim meets our veneer. Now alot of times this occurs... Read More »
Hi this is Jon on behalf of Expert Village, in this video clip I will show you how to stain our project. The first thing that I did is place some scrap wood blocks down so when I set my piece on it, it is elevated off the table. Now you would notice that... Read More »
Hi! This is Jon on behalf of Expert Village. In this video clip, we will be talking about working with wood putty. On your project you might have areas where the pin nails made holes or your trim didn't quite line up. We are going to solve this problem... Read More »
Hi this is Jon on behalf of Expert Village in this video clip we will be staining our dressers. First we need to blow off our drawers and our project and make sure that there's no loose dust on them. This is going to make the stain go on a little bit... Read More »
What kind of wood and stain is this? wfischer General Discussion 5 03-29-2008 09:49 AM
primer for wood paneling HELP! Sarah24 Painting 3 03-25-2008 03:01 PM
Deck Staining -- compatible primer & stain issue? butterclem Painting 1 03-21-2008 10:21 PM
Brick and wood flooring jhughesfam Flooring 1 08-18-2007 05:29 PM
wood stain patp General Discussion 4 03-31-2005 09:13 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
