Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 11-13-2012, 10:21 PM   #1
are wood spools an issue like pallets?
I picked up a couple of wood spools (like this one: http://pinterest.com/pin/229331805995147761/) to use them as a coffee table or side table or bookshelf/case or something. Are wood spools susceptible to the same issues as wood pallets (i.e., formaldehyde, e. coli, mold, bird/rat waste, insects, etc.)?
anuvanoob is offline   Reply With Quote
Old 11-14-2012, 05:47 PM   #2
sdsester's Avatar
Never heard these were a major problem with most pallets but I guess if you leave anything out in the elements. Isn't e. coli foodborn though?
Obviously, bacteria can get into any open surface so if you plan to eat or serve food directly on these spool table tops you should cut a piece of glass for them or otherwise seal them.
sdsester is offline   Reply With Quote
Old 11-14-2012, 10:54 PM   #3
It's earth-borne, like all bacteria. The human gut has thousands of various strains (types) of E. Coli present in it. It's a generally "good bacteria". But a few strains of e. coli are pathogenic and can make one ill, or dead. These are the strains which make the evening news.
jlmran is offline   Reply With Quote
Old wood to new wood/laminate transition dilemma. csl7037 Flooring 4 08-02-2012 07:17 PM
Stucco on wood frame issue rdksek844 Building & Construction 3 07-25-2012 10:20 PM
Regular floor screws in pressure treated wood Fred_ Building & Construction 17 07-18-2012 09:38 AM
Wood floor drying, build raised platform? Puzzles Flooring 3 05-03-2011 04:23 PM
Porcelain Wood Look Grouting Issue kbryan Flooring 12 04-13-2011 08:12 PM
