Wood Siding For A Shed - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-06-2011, 12:49 PM   #1
Rewards Points: 1,062
Question
wood siding for a shed
i wanna side my 11x9 shed with horizontal wood planks. was wondering what the most optimal material should be (price vs. looks).
thanks
Old 01-06-2011, 04:05 PM   #2
thanks
Assuming you have sheathing on it for bracing, I would suggest spruce clapboard. Cheap and cheerful for a shed
mrgins is offline   Reply With Quote
The Following User Says Thank You to mrgins For This Useful Post:
amakarevic (01-06-2011)
Old 01-06-2011, 04:22 PM   #3
Question
Sheathing as in 1/2" plywood? Certainly, that's an option but was pondering to skip it if siding vertical planks only would provide enough support (i don't care too much about insulation though I'd probably put that wrapping sheet that says "Tyvac" if I went that route - what is that sheeting called, BTW?).
Old 01-06-2011, 04:32 PM   #4
7/16 OSB is cheaper than plywood. If you don't use it, you'll need bracing on the corners or your shed will lean in the breeze!
Housewrap is the generic term. If you use anything, just use 15# felt on a shed
Old 01-06-2011, 04:51 PM   #5
Thumbs up
mrgins, DUDE YOU ROCK !!!!!!!!!!
Old 01-06-2011, 05:40 PM   #6
I try!
Vinyl siding over old wood shake?? ttam Building & Construction 15 10-26-2010 07:50 AM
Aluminum siding over existing old wood siding. timothevs Building & Construction 1 04-23-2009 04:13 PM
Board and Batten wood siding Knucklez Building & Construction 39 11-07-2008 10:38 AM
Newbee - I can't find T&G wood siding reba.sue Carpentry 7 08-08-2008 08:57 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
