Wood For Shelving - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-12-2012, 06:10 AM   #16
DIY staff
Rewards Points: 7,174
Wood glue will pop right off the polly--
Old 01-12-2012, 08:00 AM   #17
What can I use then? Besides sanding away 3 layers of poly? Lol. Is there another glue that I could use? Along with nails.
BaltimoreBamBam is offline   Reply With Quote
Old 01-12-2012, 08:31 AM   #18
DIY staff
They are just vertical supports? Nails and Gorilla glue or epoxy---Gorilla glue foams up so clamp and wipe carefully if you use it--ugly color--
Old 01-12-2012, 11:40 AM   #19
jschaben
Rewards Points: 502
There is no back on the shelf. I would sand any poly off the back edge of the shelves you want to reinforce and glue/nail 1x2's along the back edge. You could also rabbet the 1x2's so they don't protrude so far back there.
Or, you could just add a back and nail through it into the shelves.
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Old 01-12-2012, 09:53 PM   #20
Rewards Points: 2,212
Run painters tape above and below where shelf will go, the the glue gets on this and you peel it off
mae-ling is offline   Reply With Quote
Old 01-13-2012, 05:15 PM   #21
I'm going to add a back so I'll likely just do that.
Putting wood flooring on steps timbo59 Flooring 4 11-18-2011 05:20 PM
Sister joist, replace wood bean, what wood grain? jpcada Building & Construction 14 04-13-2010 07:46 AM
flooring frankiedog Flooring 7 12-05-2008 01:05 PM
DAP caulking question n0c7 Painting 16 10-31-2008 11:31 PM
Wood close to Non-IC recessed lighting-solution? sjmonty Electrical 4 12-01-2006 09:14 AM
