Wood Sandblasting - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-16-2011, 03:48 PM   #1
wood sandblasting
I have a 32yr.old log cabin in Vt. made from 6x6 pine. I want to restore inside and outside and clear coat. Anyone here have any know how on this and know of any contractors in Vt. that can do this. I understand crushed walnut shells are used and is very messy.
fitter1 is offline   Reply With Quote
Old 03-16-2011, 03:57 PM   #2
DIY staff
Rewards Points: 7,174
Sandblasting - Contractor Talk - Professional Construction and Remodeling Forum
This is a site for sand blasters----you can look but not join---However,many have their websites linked so you can contact one of them through their site.
I have read some very educational posts there----If you have any questions I'll do what I can for you.
Mike--(I'm a member ,but not a sandblaster)
Old 03-16-2011, 07:18 PM   #3
Thanks Mike.
Old 03-17-2011, 06:50 AM   #4
Mold!! Let's kill it!
Rewards Points: 2,012
Dry ice blasting works well for wood, but is not a DIY project. Also seen it done with plastic beads. Walnut shells are still pretty hard and you'd need to be really careful not to destroy the surface. Walnut shells are often used for light sheet metal to prevent shot peening and stress relieving the surface.
Old 03-17-2011, 11:00 AM   #5
What type of tools would you use for sandlbasting?
HomeProductsLmt is offline   Reply With Quote
Old 03-17-2011, 02:16 PM   #6
DIY staff
A giant tow behind compressor a hopper and a blasting gun---Thousands of dollars---not a DIY project.
Click on that link to see pictures.----Mike----
Old 03-17-2011, 04:02 PM   #7
If I sandblast a car frame or somebody's wrought iron railing, I can make 8hp worth of compressors run non stop. And that's not what it would take to do an industrial type of job. Sandblasting isn't something you want to tackle without some good knowledge and the proper equipment. Once you erode away a piece of your house with the wrong technique or the wrong blast media, there ain't no puttin' it back. Most surfaces, except for heavy iron, are unforgiving when it comes to sandblasting.
Old 03-17-2011, 04:07 PM   #8
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Why can't it be water blasted outside? That's a DIY method easy enough to do. You would raise a little fuzz in the wood grain but if it is rustic why would that matter.
There are also deck cleaning chemicals that can restore any raw wood back to its original color and appearance.
XXX
Old 03-17-2011, 06:03 PM   #9
The outside is now inside so water is not an option. I built a new camp over this one.Camp went from 20x20 to 28x38 and this is an after thought. I want to get this done before I finish the inside addition. I went with rough cut 6x6 posts and 2x8 wall with log siding to try and match what I have. BTW log cabins suck. They require a lot of maintenance.
Old 03-18-2011, 06:39 AM   #10
Then I would look for somebody who does dry ice or plastic media blasting. The only other alternative is sanding or soft wire brushing.
Old 03-18-2011, 05:17 PM   #11
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I really can't see any kind of "blasting" being a good idea now that I think about it.
XXX
Old 03-19-2011, 06:31 AM   #12
It's done pretty often, but you need to be really careful with pressures, stand off distances, nozzle types and blast media, etc. You don't want some guy who only does bridges.
Old 03-19-2011, 06:46 AM   #13
Media blasting is a great way to get that new look. I did my home a couple years back. The grain doesnt raise to much, and can be sanded down easily. You have to be careful not to harm the gaskets between the logs. A commercial grade hopper and compressor will be needed, also you will need a fresh air source as well. http://cgi.ebay.com/Supplied-fresh-A.......Personally if you have never done this type of work before I would leave it to a pro. Try giving these guy`s a call http://www.vermontcedarloghomes.com Either way you go, Good Luck To You.
mark942 is offline   Reply With Quote
Old 03-19-2011, 08:34 AM   #14
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Remember" If women do not find you handsome, They should at least find you handy"
Shouldn't you be giving credit to the true author for that quip?
Shouldn't it read:
Remember: "If women do not find you handsome, They should at least find you handy."
-Red Green
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
tpolk (04-01-2011)
Old 04-01-2011, 04:45 AM   #15
Dry ice blasting is good for wood?
desiree_furman is offline   Reply With Quote
Sister joist, replace wood bean, what wood grain? jpcada Building & Construction 14 04-13-2010 07:46 AM
Replacing Carpet on Stairway with Wood jkirby39 Carpentry 3 01-24-2009 12:42 PM
flooring frankiedog Flooring 7 12-05-2008 01:05 PM
DAP caulking question n0c7 Painting 16 10-31-2008 11:31 PM
Wood close to Non-IC recessed lighting-solution? sjmonty Electrical 4 12-01-2006 09:14 AM
