Is This Wood Rotted - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-30-2014, 09:31 PM   #1
Rewards Points: 2,176
Is this wood rotted
The edge of the door, from garage into laundry room, has these grooves. Today priming the other doorway in laundry room I found 2 more areas like this. They're about 2' up from floor and the areas are about 16" tall.
On the other side of the doorway (inside laundry room) I see definite scratches like from a pet that was closed up in laundry room. But that can't be reason for the gouges outside the laundry.
I had a clean termite inspection when I moved in.
The wood is 30 yo oak.
Startingover is offline   Reply With Quote
Old 01-31-2014, 07:58 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,226
Not likely.
Is it soft? If it is near the base, the wood can draw moisture from the bottom but that doesn't look like what is happening there.
The Following User Says Thank You to Windows on Wash For This Useful Post:
Startingover (01-31-2014)
Old 01-31-2014, 08:02 AM   #3
Rewards Points: 13,960
Looks like claw marks to me.
Not worth taking the time to sand. Want it to look better? Just replace it with new wood.
Old 01-31-2014, 08:12 AM   #4
Rewards Points: 153
There is no reason you'd get rot on trim like that in just a 16" area and a couple feet from the floor. It looks like claw marks to me.
eandjsdad is offline   Reply With Quote
The Following User Says Thank You to eandjsdad For This Useful Post:
Old 01-31-2014, 08:55 AM   #5
Rewards Points: 1,476
Poke it with a screwdriver. Does it go into it?
mikegp is offline   Reply With Quote
The Following User Says Thank You to mikegp For This Useful Post:
Old 01-31-2014, 10:50 AM   #6
Rewards Points: 153
There is a possibility that it's old termite damage. I've seen them tunnel just under the paint surface - when you take the paint off, it can look like that.
Old 01-31-2014, 11:56 AM   #7
I poked it with screwdriver and wood is hard.
I'd go with scratch marks but it's also on edge of door going into garage. Strange that it's on both sides of doorway and up fron floor same distance.
I don't blame home inspector for not seeing it or the termite guy as this hallway is a bit dark.
For now I'll paint over it. Somedayll try to replace the wood.
When my wallet recovers from Xmas I'll be calling the termite guy to get on schedule, as he suggested when I moved in.
Thank you, everyone. I don't know what I'd do without all the advice here.
Old 01-31-2014, 12:04 PM   #8
On a new subject regarding wood..........the reason I won't try replacing wood now is that I can't hammer straight.
I replaced a short PC of baseboard behind dryer. Not much space to work in and it was so hard to nail. For every strike of the hammer I only hit the nail 1 out of 5 times. What is the secret to hitting the nail? I bent many nails. And, I dented the baseboard terribly. Finally I just hit the nails at the side and wrapped them up on the baseboard since I couldn't get them in. I hate that it's do sloppy looking but as it's behind the dryer I won't have to look at it.
Old 01-31-2014, 01:00 PM   #9
Gymschu's Avatar
Rewards Points: 930
Nail holder may help.
The Following User Says Thank You to Gymschu For This Useful Post:
Old 01-31-2014, 01:04 PM   #10
Pneumatic nail gun.
I never would, but you can also predrill the hole in the trim.
Old 01-31-2014, 01:05 PM   #11
Never heard of a nail holder before.
Old 01-31-2014, 01:12 PM   #12
You can get a compressor and nail gun for pretty cheap. I got this one new for $50 on sale from sears:
http://www.craftsman.com/craftsman-e...p-00915206000P
Great for chair rail, crown molding, baseboards, etc.
Old 01-31-2014, 02:57 PM   #13
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,394
From the pic it looks like old wood with raised grain.
Pugsy.....my project: Total House Rebuild Bungalow to Two Story
123pugsy is offline   Reply With Quote
The Following User Says Thank You to 123pugsy For This Useful Post:
Old 01-31-2014, 03:48 PM   #14
Here's another photo.
Old 01-31-2014, 03:50 PM   #15
Gymschu's Avatar
Rewards Points: 930
^^^^That pic looks a bit more suspicious, perhaps some termite damage, although I hope not, SO.
Rotted wood under siding: Repair Help? (See Pictures) LevTownMike Remodeling 3 06-25-2012 05:03 PM
Rotted wood & Fieldstone foundation repair Glenmc Building & Construction 7 06-01-2012 07:49 AM
Condensation rotting wood below display window of a cooler. drw158 Insulation 3 03-10-2012 12:42 PM
Wood floor drying, build raised platform? Puzzles Flooring 3 05-03-2011 03:23 PM
Ext Paint for Interior Application? PaoloM Painting 24 04-21-2009 04:30 AM
