Wood Posts - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-19-2012, 03:24 PM   #1
Rewards Points: 2,072
wood posts
Had a 6' fence put in with a small area that is 4'.
Just noticed that many of the supporting posts have cracks. Is this normal? I sure hope so cause I'd dread having to deal with the fence contractor if it's not normal. I didn't notice it, or even look, before paying him.
attached are 3 of the many posts with cracks.
Startingover is offline   Reply With Quote
Old 07-19-2012, 05:38 PM   #2
Civil Engineer
Rewards Points: 4,572
Pressure treated wood is notorious for cracking, that is perfectly normal for PT lumber. Not saying it is pretty, but it is normal.
The Following 2 Users Say Thank You to Daniel Holzman For This Useful Post:
mae-ling (07-19-2012), Startingover (07-19-2012)
Old 07-19-2012, 05:42 PM   #3
daniel,
Whew. Thanks. That's a big relief off my mind.
At my last house I had a fence but it was far away and I didn't look at it closely. This one section is right outside an access door so I view it up close every day.
Old 07-19-2012, 05:44 PM   #4
Rewards Points: 13,300
It's called checking, some have it even when there brand new in the store.
Startingover (07-27-2012)
Old 07-19-2012, 06:03 PM   #5
In a little over my head
Rewards Points: 706
Yup. Pressure Treated lumber does that.
ratherbefishing is offline   Reply With Quote
The Following User Says Thank You to ratherbefishing For This Useful Post:
Old 07-19-2012, 11:25 PM   #6
Rewards Points: 506
Is it because it's PT or is it the nature of the wood species which is most often (always?) PT...which i believe is pine?
jlmran is offline   Reply With Quote
The Following User Says Thank You to jlmran For This Useful Post:
Old 07-20-2012, 07:10 AM   #7
kwikfishron's Avatar
Rewards Points: 202
It's the Pine...On the West Coast the PT is mostly Fir and that kind of checking is rare. There's a budget grade of PT that's usually Hemlock that will twist and check but nowhere to the extent I've seen with Pine.
This is a typical PT 4x4 we use out West treated with Copper Azole.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
Old 07-20-2012, 09:26 AM   #8
Retired Cabinetmaker
woody4249's Avatar
Rewards Points: 156
We get that checking in PT here in Florida too. Fence pickets look great on the pallet but a week or so on the fence and they are twisting and cracking.
The one I put up in my old back yard was cypress and didn't have any issues.
Mike.
"I'm not as green as I am cabbage looking"
woody4249 is offline   Reply With Quote
The Following User Says Thank You to woody4249 For This Useful Post:
ICF vs. Wood Framed JackOfAllTrades Building & Construction 31 11-01-2011 04:14 PM
Wood floor drying, build raised platform? Puzzles Flooring 3 05-03-2011 04:23 PM
Attaching wood posts to top of existing foundation wall tpagel Building & Construction 1 04-14-2011 11:19 PM
How to replace wood support posts under main beam webjanet Building & Construction 1 09-07-2008 11:15 PM
Cracks in pressure treated posts (4x4s, 6x6s) Deck Building & Construction 8 05-15-2008 11:57 PM
