Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 08-24-2010, 10:12 PM   #1
Wood Panel Under Door Sidelite
Can any one tell me if the wood square panel like pieces under the 1/2 sidlites of an entry door can be repaired or replaced. The 1/2 window parts of the sidelites are fine and completely sealed, but the wood panels (squares) underneath the windows area are showing signs of deteriation (ei. spliting &t hining). One home improvement store clerk informed me that I may have to replace the entire door frame unit if it's a whole manufacture unit, however the door frame still seems to be still very sturdy. Again, just wanted to know if it is possible to repair or replace these wood panels within the entry door sidelites?
Thanks for your help,
Rmisty
3 threads on the same issue merged
Moderator
rmisty is offline   Reply With Quote
Old 08-25-2010, 12:54 PM   #2
Old School
Willie T's Avatar
Without seeing it, it's hard to say. But it is most likely that you will be able to simply remove the old panels and their stops, then replace with new.
If they are inset into the jambs, you can still add stops and have it look just fine.
Willie T
The Following User Says Thank You to Willie T For This Useful Post:
rmisty (08-25-2010)
Ready to paint the porch! Oil or latex? Leah Frances Painting 8 07-26-2011 08:29 PM
Passing wire to another panel theatretch85 Electrical 5 09-21-2009 12:09 AM
Panel Placement In Outbuilding smitty286 Electrical 3 03-31-2008 01:20 PM
Filling wood panel nail holes Sarah24 Painting 1 03-14-2008 01:48 PM
breaker panel question chadvavra Electrical 11 08-10-2007 10:20 AM
