Wood Handrail Q? - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-08-2010, 07:46 PM   #16
just remember stay a way from the wall 1/1/2 or 1 5/8 no less than that good luck
Wood Handrail Q?-stairs-made-ronald-1647.jpg   Wood Handrail Q?-stairs-made-ronald-1648.jpg
01stairguy is offline   Reply With Quote
Old 04-08-2010, 08:19 PM   #17
I think we should go with the stairguy's advice. Something about the name tells me he knows what he is talking about.
beerdog is offline   Reply With Quote
Old 04-09-2010, 11:32 AM   #18
Stairguy....couldn't it also be easily done with fittings? Obviously it would be a little more cost due to the fittings. And it takes more skill since more work is needed to join the fittings, but it would give a nice curved look. I am sure you have done it a 1000 times, but here is a picture of a wall rail I made for my house that is half of what he would need. Would just need an up-ease to the next railing run.
Old 04-09-2010, 04:11 PM   #19
yes the best way will be with the fitings, but if hi is doing it for him self i will spend that kind of money, but if this is for some body else i dont know unless if they are willing to pay for the parts and labor, you know how that goes now in days, cheap cheap cheap God we can't make no money any more:laug hing:
Old 04-09-2010, 04:15 PM   #20
some a little different
Old 08-06-2012, 08:35 AM   #21
OK, bringing this back from the dead. I'm looking at doing this same thing. I have a half wall that I am going to put a banister up and then have two more stairs that will need a handrail. So you just have your regular rail and then an L type jog, like this Handrail Jog which you then immediately tie into the wall after it makes the turn? My only concern with that was the strength of the banister on the half-wall portion. My length is about 5' before I make the turn. I'm wondering if I should do it the way you have laid out or if I should terminate it at the wall and then hand short section that I mount to the wall, but wouldn't be "continuous".
agreif is offline   Reply With Quote
Old 08-06-2012, 07:54 PM   #22
recently retired
Rewards Points: 280
That thread was better off dead...
Keith Mathewson is offline   Reply With Quote
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Correct wood for exterior handrail? darsunt Building & Construction 6 11-20-2009 04:06 PM
Ext Paint for Interior Application? PaoloM Painting 24 04-21-2009 04:30 AM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 09:14 AM
