Wood Handrail Q? - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-08-2010, 11:26 AM   #1
Rewards Points: 33
Wood Handrail Q?
Hey guys,
I'm putting on hand rails for my basement project. My stairs take a 90 degree turn as seen in the picture below. When I put the railing in, should i make it one continuous piece and miter the corner, or make it two pieces?
hope this makes sense.
philly529 is offline   Reply With Quote
Old 04-08-2010, 11:33 AM   #2
One continuos rail would be best, but if you do it in 2 sections you will probably be required to do a return at each end.
hayewe farm is offline   Reply With Quote
Old 04-08-2010, 11:51 AM   #3
Yes. One continuoius piece will look nicer,but it will take more skill to build. If 2 pieces, you need to return them to the wall to meet codes. You can buy standard fittings to accomplish the 1 piece build. There are some good resources on the web to learn more. Search stair building codes. Also visit LJSmith.com. They have a good stair and handrail building guide.
beerdog is offline   Reply With Quote
Old 04-08-2010, 02:01 PM   #4
kwikfishron's Avatar
Rewards Points: 176
I would keep it continues, people who need the handrail would rather keep their hands on something the entire journey up or down the stairs.
kwikfishron is offline   Reply With Quote
Old 04-08-2010, 02:05 PM   #5
Rewards Points: 33
Hey thanks for all your replies.
I would want to make it one continuous railing, but there doesn't seem to be a way to miter an outside corner on an angle like that.
Any ideas?
Old 04-08-2010, 02:08 PM   #6
Rewards Points: 33
What do you mean by standard fittings?
Old 04-08-2010, 02:13 PM   #7
people do it all the time. Compound miter saw or buy fitings. Google stair railings and you will find pictures. You can also buy fiittings for making turns. You can see them on the LJSmith web site. Doing this is actually very common. Using premade fittings will give you a nice curved turn. You can even buy everything at the big box home centers.
Old 04-08-2010, 02:20 PM   #8
Rewards Points: 33
I have looked online for a few hours today and cannot find anyone that shows how to make an outside corner turn down stairs. any insight into this?
Old 04-08-2010, 02:21 PM   #9
HEre are some fittings
http://www.stairwarehouse.com/6010-p...-fittings.html
application aexample
http://images.google.com/imgres?imgu...26tbs%3Disch:1
http://greeffsteelworx.yellowpages.c...and%20rail.JPG
Old 04-08-2010, 02:22 PM   #10
Hit the library. There are plenty of good books on building ballustrade (hand railing).
Old 04-08-2010, 02:27 PM   #11
you could do it several ways.
1. use a quarter turn (90 degree) fitting.
2. combination of 90 degree turns and over and under eases. Eases are a type fitting.
3. custom compound miters. Usual approach is to use fittings though.
Remember that building custom ballustrade is one of the more difficult fields of carpentry. It requires perfect cuts and measurements. You might want to get it quoted unless you really want to do it yourself.
Old 04-08-2010, 03:50 PM   #12
if the city is going to inspect this job and if they require a continus wall rail, then you are gonna have to do it via miters, and if this is a simple wall rail then will be a lot easier you can ret a way in doing it in 2 sections and each wall rail you can return each end with 45* degree miter cut return it to the wall, by the way the wall rail has to be a least 1 1/2 a way from the finished wall.
01stairguy is offline   Reply With Quote
The Following User Says Thank You to 01stairguy For This Useful Post:
philly529 (04-08-2010)
Old 04-08-2010, 04:03 PM   #13
Rewards Points: 33
hey thanks, I am def going to do this in 2 sections. i don't see a way that i would be able to do it on continuous section.
Old 04-08-2010, 05:06 PM   #14
look at the picure link I attached. It is your same application. You can do it. but 2 pieces would make it very easy.
Old 04-08-2010, 08:31 PM   #15
this is the real thing that you have to do is simple
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Correct wood for exterior handrail? darsunt Building & Construction 6 11-20-2009 05:06 PM
Ext Paint for Interior Application? PaoloM Painting 24 04-21-2009 05:30 AM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 10:14 AM
