Wood Filler That Is Actually Stainable - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-09-2011, 02:19 AM   #1
Rewards Points: 206
Wood filler that is actually stainable
I have used a few different types of the Elmer's wood filler that states it is stainable, but whenever I stain the area, the stain doesn't take too well. I usually use it to cover up countersink holes and there is always a lighter round spot there. Any ideas as to what I should do or buy? I went to HD and asked and the guy handed me a Minwax product that matched the stain perfectly. Stupid me, I didn't read it until after I opened it and it turned out to be a clay. It matched perfectly, but it doesn't harden. Thanks
joeg679 is offline   Reply With Quote
Old 07-09-2011, 06:27 AM   #2
DIY staff
Rewards Points: 7,174
I usually wait to fill holes until the wood is stained and the first coat is on.
I know of no stainable filler that looks good.
joeg679 (07-09-2011)
Old 07-09-2011, 07:22 AM   #3
Rewards Points: 5,336
As Mike said, the stainable fillers are somewhat of a myth. They stain, just not the same color as the wood. For counter sinks, I'd use wood plugs. for nail holes, I stain and poly and then fill them in with the wax crayon sticks from Minwax.
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
Old 07-09-2011, 07:57 AM   #4
Too Short? Cut it Again!
Some times, with patience, you can get a gel stain on a patch to come close to the surrounding material. Use a q-tip.
The Following User Says Thank You to user1007 For This Useful Post:
Old 07-09-2011, 08:04 AM   #5
Civil Engineer
Rewards Points: 4,682
Another option is to mix sawdust from the actual wood with glue, and use the mix to fill the nail holes. It works pretty well, and will take stain, but due to grain issues, will not look perfect. Plugs look pretty good, but due to the round shape, they are also visible, even though they take stain correctly.
Daniel Holzman is online now   Reply With Quote
The Following 2 Users Say Thank You to Daniel Holzman For This Useful Post:
joeg679 (07-09-2011), Willie T (07-09-2011)
Old 07-09-2011, 09:25 AM   #6
Rewards Points: 206
Great. Thanks for the replies!
Old 07-09-2011, 09:31 AM   #7
have you tried mixing stain pigment from can with filler then hole filling? try on scrap first
The older I get the better I was
Old 07-09-2011, 10:10 AM   #8
Rewards Points: 190
You can also get in a craft store a basic set of acrylic artists colors and a few small artists brushes. Mix red,yellow and blue and you have brown. Add a little water and it is a stain instead of paint. Need golden oak-add more yellow, cherry-add more red, walnut-add more blue. You can match any color. Results vary with skill level. Guys that are sent out by furniture stores to fix dings in furniture shipped to customers if they are good can make invisible repairs.
zircon is offline   Reply With Quote
The Following 2 Users Say Thank You to zircon For This Useful Post:
joeg679 (07-09-2011), oh'mike (07-10-2011)
Old 07-09-2011, 12:17 PM   #9
Stealing real crayolas from kids when they are not looking and melting matching color wax into scratches and things can buy you time. Could work for plugs?
Old 07-09-2011, 07:39 PM   #10
jules4's Avatar
This is what I do too - it works really well, but if doing a dark stain you have to add quite a bit of stain to the filler and this slows down the curing time so plan accordingly (rather than 24 hours, I've had to wait as long as 3 days for the filler to fully harden).
jules4 is offline   Reply With Quote
Old 07-10-2011, 04:21 PM   #11
DIY staff
Another old time filler --shellac sticks--There is a learning curve with those--however,I find them handy in certain circumstances.
Old 07-10-2011, 07:44 PM   #12
jules4's Avatar
Do you mean lacquer sticks (i.e., the solid coloured, sort of glassy sticks that you melt to fill holes?)
I've used shellac buttons and shellac flakes, but I've never encountered shellac sticks.
Old 07-10-2011, 10:35 PM   #13
Rewards Points: 206
I have actually tried that, but it didn't really work that well for me. I'm going to try a bunch of these suggestions on a scrap piece of wood, including the above one, again. Thanks a lot
Old 07-11-2011, 05:06 PM   #14
jules4's Avatar
If you want to try lacquer sticks Lee Valley sells them (like Mike said, there's a learning curve to using them, but after that you can get pretty flawless results): http://www.leevalley.com/US/wood/pag...190,42997&ap=1
Old 07-13-2011, 07:43 AM   #15
DIY staff
I never hear of them called 'lacquer sticks' --but yes,melt with an alcohol
lamp and apply with an artists spatula.
They are getting hard to find.
I use a scrap of aluminum foil to protect the surrounding area from getting unwanted material on it.
Ext Paint for Interior Application? PaoloM Painting 24 04-21-2009 04:30 AM
Amber Colored Wood Filler to Match Oak Steps MrBill_DIY Flooring 2 11-15-2008 07:31 PM
DAP caulking question n0c7 Painting 16 10-31-2008 11:31 PM
Wood close to Non-IC recessed lighting-solution? sjmonty Electrical 4 12-01-2006 09:14 AM
