Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 12-01-2012, 11:18 AM   #1
baandla's Avatar
wood countertops
Hello all ,
I'm in the process of renovating a house that we plan to rent out. I've never done this before but so far I have managed to figure it out along the way(thanfully). In the kitchen I am at the point where Im ready to install these wooden countertops. I was wondering if anyone could suggest the best way to finish/protect them? I believe they are an "exotic" wood. The name of the wood was acai..? I purchased them at a local salvage/importer type store and cut them to fit. I bought a pour on epoxy glaze coat, two different ones actually. one is from Rustoleum and one is Famowood. My plan was to use one of these but upon doing research on them I've read mixed reviews. Any suggestions from my trusted DIY chatroom would be greatly appreciated.
SIDE QUESTION: anyone know where I can find a bottom bake element for this stove? Its a Hotpoint model 208RH171. I've seen some on ebay that look like they may work but they dont specify that particular model number. I emailed the person selling them that stated they could look it up. They replied back saying they could not find anything in the catalog on this model and that i would have to go by specs, which I will if I have to but I thought I would run it past you guys first.
Thank you, Brandy
baandla is offline   Reply With Quote
Old 12-01-2012, 03:52 PM   #2
wood countertops
http://www.repairclinic.com/Shop-For...08RH171-%3d%3d
IF YOU TRY AND USE A SEALER INSTEAD OF AN OIL ON THOSE COUNTER TOPS i CAN SEE THAT BECOMING A BIG MAINTAINCE ISSUE.
http://www.bing.com/search?q=CUTTING...sp=-1&qs=n&sk=
Old 12-01-2012, 04:40 PM   #3
baandla's Avatar
wood countertops
Thanks joe. So the pour on glaze is a sealer?
Old 12-01-2012, 05:00 PM   #4
funfool's Avatar
wood countertops
Is a food grade oil you rub in, is basically all I use on butcher block counters.
Just wipe it on and run away.
Will need to be reapplied as time goes on, But I would not use anything else myself on it.
Can be bought at the big box stores.
If it was easy, we would not call it work!
funfool is online now   Reply With Quote
Old 12-01-2012, 05:01 PM   #5
wood countertops
I'd guess so I can not see the can.
Might be ok for something like a bar top but not for a kitchen counter top.
Old 12-01-2012, 06:43 PM   #6
baandla's Avatar
wood countertops
Thanks guys, y'all have saved me a lot of headache and work.
Old 12-01-2012, 08:41 PM   #7
wood countertops
I have bad news for you.
I have a 6' cherry countertop in my home. I have coated it with mineral oil twice, the first time I really soaked it in. It has been there for 8 months I suppose.
It was beautiful when I installed it and it still is.
Problem is you have to be very careful with it. Placing wet glasses, pots/pans, anything on it and you are in trouble.
Poor choice for a rental.
cleveman is offline   Reply With Quote
Old 12-01-2012, 11:06 PM   #8
baandla's Avatar
wood countertops
well.... perhaps it is a bad choice but I have very little invested in these counter tops($129.00). And while id like for them to stay beautiful forever..... in the long run, if they look bad I dont see it as something that sandpaper couldnt fix. Just trying to avoid that if possible.
Old 12-01-2012, 11:18 PM   #9
wood countertops
Maybe give them a bottle of mineral oil and tell them to have at it once a month.
It is like telling your wife to put air in the tires or check the oil every time she drives the car. You know it won't happen.
Guess it is worth a try for $129.
Old 12-02-2012, 12:03 AM   #10
baandla's Avatar
wood countertops
(Laughing), you sound like my husband. Your right though. Oh well, time will tell and lessons will be learned.
Old 12-02-2012, 11:49 AM   #11
wood countertops
Your best chance of finding a heating element is to take your part down to Parts House and have them try to find a part to match yours.
Your Hotpoint range was made in the day before the appliance makers used computers to store model and part information. Product Info from that era was never placed in the computer data base that we use today, so todays computer generated parts info will not list your Hotpoint range.
Good Luck
Bruntson is offline   Reply With Quote
Old 12-02-2012, 12:00 PM   #12
wood countertops
The difference in a countertop sealer and an oil is that a sealer lays on the top of the wood. It will chip, scratch and show knife cut marks. The sealer leaves a smooth, tough surface and does a nice job resisting these marks if it is taken care of...but then you are going to use it in a rental. If at a latter date you want to use the sealer to touch up chips and dings, the result is ugly with questionable adhesion.
An oil finish is absorbed into the pores of the wood, and lays just below the woods surface. Repairs and refinnishing is just a wipe down of the oil on an rag. The downside is it is only moisture resistance.
Since the repairs are so easy with oil that is what IO would use (I own over 30 rentral units for the last 28 years).
Bruntson
Old 12-02-2012, 01:47 PM   #13
baandla's Avatar
wood countertops
Thank you Brunston for your valuable information, insight, and time. I will do just that(your suggestions).
Old 12-03-2012, 09:06 AM   #14
wood countertops
I know you're set on it, but I would never, ever install wooden countertops. But, on the plus side, they're going to look so crappy when the first tenant moves out that you'll get to keep their security deposit.
Old 12-05-2012, 12:09 AM   #15
baandla's Avatar
wood countertops
You guys crack me up! Way to see the silver lining though Md . I'm going to choose to remain positive on this one. Surely there's a renter out there bright enough go wipe down a counter with mineral oil once a month.
Putting wood flooring on steps timbo59 Flooring 4 11-18-2011 06:20 PM
ICF vs. Wood Framed JackOfAllTrades Building & Construction 31 11-01-2011 04:14 PM
"DIY wood countertop" - is it really DIY? ranchmakeover Carpentry 8 10-20-2011 02:34 PM
Sister joist, replace wood bean, what wood grain? jpcada Building & Construction 14 04-13-2010 08:46 AM
Wood to Concrete without Drilling MattStata Carpentry 1 04-19-2006 05:16 PM
