Wire Or Insulation Next? - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-13-2010, 09:32 PM   #1
transmitterrecieverpntgun
wire or insulation next?
After framing up an exterior wall in a summer cabin (2x4 24oc wall w/ osb exterior than siding) what comes next, Insulation or wiring? I know, stupid question huh....but i cant remember and I am NOT a carpenter...lol the insulation is 24 oc faced.
utilitylocator is offline   Reply With Quote
Old 08-13-2010, 10:57 PM   #2
Well I don't know how you'd run the wires if you were to put the insulation in first, so go with wiring then insulation.
sausagefingers is offline   Reply With Quote
Old 08-14-2010, 06:16 AM   #3
Yep, wiring first. The wires need to be stapled or run thru holes in the center of the studs, joists, etc. Inspections(rough) are required before insulation can be installed. Then insulation inspection is needed before drywall.
Old 08-14-2010, 05:22 PM   #4
As others said, wiring first.
Hohn is offline   Reply With Quote
What type wire to use from transfer switch to outdoor outlet brjl Electrical 32 11-20-2013 08:36 AM
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Fishing Wire - Foam Insulation bohaiboy Home Theater 14 01-18-2010 05:41 PM
Melted Service Entrance Wire in Panel theatretch85 Electrical 13 08-22-2008 10:37 AM
attic insulation question dderolph Building & Construction 10 11-03-2007 05:21 PM
