Wine Rack - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-14-2010, 01:18 PM   #1
Wine Rack
I want to build a small wine rack to place on the counter between a pantry and our fridge. We have a small 9 bottle one there now, but I would like to build one that will fill the entire space to hold more bottles. The space is 18"x18" I've found some plans online but none that are the style we like. I'm looking for one with the "lattice look" which is essentially diamond shapes that each bottle sits in. If anyone can help me out I would greatly appreciate it!!
Troy
lucky8926 is offline   Reply With Quote
Old 12-14-2010, 04:38 PM   #2
I would build a box out of plywood (grade depending on whether you paint it or stain it), with a back on it. Then use some 1x2 hardwood strips and notch them so they fit together diagonally. You could also make them so they're at 90* to each other. I'd make a full size template so you can figure where to notch the pieces.
mrgins is offline   Reply With Quote
Old 12-14-2010, 05:15 PM   #3
Rewards Points: 558
Here you go: http://www.thehardwarehut.com/catalo...php?p_ref=3851
http://woodworker.com/fullpres.asp?P...5&LARGEVIEW=ON
epson is offline   Reply With Quote
Old 12-14-2010, 07:05 PM   #4
The prices are for the valances, not the racks. Hth
Old 12-15-2010, 12:08 PM   #5
The main thing I need help on is the racks themselves, how to get the crosshatch pattern
Old 12-15-2010, 01:52 PM   #6
uva uvam vivendo variafit
WirelessG's Avatar
Rewards Points: 690
You need to layout the hatch on cabinet or on paper to make sure it will fit and so that you don't up with 7.4 holes (more than anything else, you need to make sure it is symmetrical). Traditionally, this would be done on a 45 degree bevel. If the side of a hole (measured on a 45 deg angle) is 4", then the width of the hole will be 2*4*cos45 = 2*4*0.707. Once that layout is done, the lattice can be made by either hogging out half of the thickness in each piece at points of contact so that they lap and their faces are flush with each other or you can simply lap one set on top of the other set and glue them together (using brad nails at each point to hold the assembly together while the glue dries). Hogging out the contact points can be done with a router or with a set of dado blades in a table saw.
I don't know if this makes sense to you. I don't think I can make it any clearer without providing drawings. If it doesn't make sense, then I would suggest you buy a set of plans off the internet. The plans shouldn't be expensive and, even if want to modify the plans, the original design will show you how to put it together.
WirelessG is offline   Reply With Quote
Old 12-15-2010, 02:59 PM   #7
Rewards Points: 558
No the prices say wine racks available “with matching valances” you don’t have to buy the valances. Anyway, here is a link on how to build a lattice wine rack. http://www.ehow.com/how_5478816_build-lattice-wine-rack.html
Old 12-16-2010, 07:18 PM   #8
I think thats what I said, but mine reply was in English!
Installing wall mount rack on a concrete wall? helpless handyman Building & Construction 5 08-20-2010 10:33 PM
Mounting Checkolite pot rack with lighting Warner Electrical 2 06-16-2010 02:56 PM
Random GFCI tripping, Data Rack theatretch85 Electrical 5 07-10-2009 09:20 PM
Removing Towel Rack to paint bathroom bigbearok Painting 3 02-12-2009 06:40 PM
thermostatic controled wine rizaydog Electrical 3 12-31-2007 03:25 PM
