Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 08-31-2012, 09:25 PM   #1
Wine Fridge built-in HELP
Hi, I want to built a "cover" around a wine fridge that needs to go on the 2 sides and top. I need it to look like a built-in. Wondering if i can get some help on how to make it look like a built-in and what type of wood to use. I am still a moderate beginner so if this doesn't sound professional then that's why. Thanks a lot
Chase5050 is offline   Reply With Quote
Old 08-31-2012, 09:34 PM   #2
May want to pick up a book on cabinet building to give you some pointers.
I would use 3/4" cabinet grade plywood with birch face frame.
One the back it could be just 1/4 A/C plywood.
range and fridge next to each other? Tudy Appliances 4 09-23-2010 06:21 PM
Kenmore fridge stops cooling with frost in freezer donnoit Appliances 3 09-20-2010 08:59 AM
Fridge compressor convert to air compressor? jogr Appliances 1 04-24-2008 02:10 PM
Water tube to fridge... Wolf_22 Appliances 9 04-04-2008 01:36 PM
Freezer leaking into Fridge? jc2709 Appliances 1 05-23-2007 10:55 AM
