Windowsill Woes - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-11-2008, 12:29 PM   #1
Question
Windowsill Woes
Howdy.
I recently replaced some windows. Now I need windowsills, and I'm not sure how to proceed.
The exterior walls are made of cement block. There is currently a gap (shown above) that I need to somehow fill. Ultimately, I would like to tile the windowsill, but I figure I should drywall first.
How do I make sure I get a nice and even windowsill? Should I use shims? Should I use cement? Should I just toss some drywall on there, and mud and sand for a few hours?
Any tips, ideas or links to tutorials will be greatly appreciated.
Josh the Jenius is offline   Reply With Quote
Old 02-11-2008, 01:45 PM   #2
Custom Cabinet Maker
Scribe,cut and fit only way to do it. Is that sheetrock on there now? If so get it out of there. Use 5/4 for sill, caulk the seam under the window first then make your sill, PL500 to hold it if it is block construction and no way to nail it down.
Just re-read your post, since u want to tile then tile it! NO sheetrock underneath, scrape and clean the surface well, caulk, then thinset and tile done
skymaster is offline   Reply With Quote
Old 02-11-2008, 02:00 PM   #3
skymaster:
Sorry to be stupid but I am confused.
Under the window is cement block.
Should I tile directly onto the cement block? I don't think tile is thick enough to cover the gap.
Old 02-11-2008, 02:11 PM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Yes, right on the cement block - assuming that it is level and smooth.
If if is not thick enough to cover the gaps, then install a layer of 1/4" duroc or hardie board over the block using thinset or Strong contruction adhesive.
- Build Well -
Old 02-11-2008, 05:07 PM   #5
Home Remodeler
Rewards Points: 164
Nice looking windows.
mikey48 is offline   Reply With Quote
Craftsman miter saw woes Joebloggins` Tools 8 11-01-2011 09:13 PM
Windowsill? kcrossley2 Building & Construction 15 09-16-2007 01:10 PM
New Fence Woes mikedbom Painting 2 09-12-2007 05:27 PM
dryer woes... cisco10 Appliances 3 09-02-2007 03:46 PM
