Window Trim Ideas, Please Help? - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-03-2012, 03:05 PM   #1
Rewards Points: 89
window trim ideas, please help?
HELLO ALL,
NEED SOME TRIM ADVICE, 3 WINDOWS TOGETHER AS BELOW. I HAVE ANOTHER WINDOW THE SAME WAY. THEY ARE ALL CLOSE BETWEEN 4 3/4 TO 5 INCH INBETWEEN. THIS IS MY FIRST TRIM JOB ON MY HOUSE SO I'M NOT SURE HOW TO DO IT OR WHAT WOULD LOOK BEST. I HAVE A 3 INCH WIDTH ON THE WINDOW STOOL AT THE END OF THE SMALLER WINDOWS. I WAS THINKING: CUT A 1 X 5 PRIMMED PRIME TO WIDTH AND JUST ROUTERING THE ENDS. BUT MAYBE YOU GUYS HAVE A BETTER IDEA.
the TOP WAS GOING TO BE A CROWN MOULDING HEADER WITH A 1 X 3 REVIEAL BEFORE THE CROWN STARTS...I HOPE I'M SAYING THIS RIGHT..
THANKS AGAIN
CHIP,
BALTIMORE
chipraynor is offline   Reply With Quote
Old 01-03-2012, 03:46 PM   #2
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,124
just go as planned, make some custom casing out of flatstock which is the same width on the two ends then make one peice for in between windows. it will keep the look consistant, plus it makes it easier for the painter. unless your proficient at custom trim i wouldnt try to join the middle to the header with mitres, if you can get away with it use a boston header which has thicker stock up or break up the transition via bullnose molding
also.. take your caps lock off
woodworkbykirk is offline   Reply With Quote
Old 01-03-2012, 03:59 PM   #3
Rewards Points: 13,468
Most often the area between the windows is done with a mullon strip.
http://www.eastcoastmouldings.com/ma...ubcategory=117
Old 01-03-2012, 06:46 PM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 304
You could trim like this window but maybe install flutes for the sides and mullions
and even run the flutes to the floor with plinths. Maybe recessed panels or raised panels
under the windows or just shadow boxes.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 01-03-2012, 07:22 PM   #5
Tom Struble's Avatar
Rewards Points: 2,002
nice looking casing work there Jim
Tom Struble is offline   Reply With Quote
Old 01-03-2012, 07:46 PM   #6
Ole Wood Worker
BigJim's Avatar
Rewards Points: 304
Tom, I would appreciate it but it isn't mine, I had it saved for showing a friend of mine how to trim a window.
Jim
crown molding meets window trim sonofthetonsured Carpentry 13 03-19-2011 12:33 PM
Wooden window trim that I stripped looks bad. Suggestions? jpearson311 Painting 15 04-28-2010 09:15 AM
How to trim window ryan16 Carpentry 9 02-27-2009 09:56 PM
Stool and Apron Window Trim Style Advice DIYCarp Carpentry 8 01-24-2009 09:31 AM
locate a vendor for vinyl window pane trim bjr23 Remodeling 1 02-13-2005 11:59 PM
