Window Trim Bevel - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-05-2010, 01:09 PM   #1
window trim bevel
This one should be easy!
Putting on some new window treatments in a 50's era house we bought recently. But, I'm finding that the hardware that comes with the things we're buying, isn't playing well with our situation.
The mounting clips that come with several new cellular blinds usually comes with two options - screw holes horizontally, or screw holes going up vertically. (Seems typical of most of these clips.)
* Going horizontal isn't going to work for me, because that would go right into the plastic base of our windows (pic 1 below).
* So, to get a good bite on wood, I think I need to go UP. However, our wood trim around the windows has a bevel. And I'm finding that the pre-made holes in the clips are too far out. (see pic 2)
The first set of blinds we bought had this problem, and we thought it a fluke, and returned them. Now the second has the same problem. Is our wood trim just old (and narrower) than newer stuff?
For reference sake, also showing a pic of the old mounting clips from 80's era blinds. They seemed to provide ample opportunity for screw holes very tight in against the window. (pic 3)
Any help appreciated.
window trim bevel-plastic-issue.jpg   window trim bevel-bevel-issue.jpg   window trim bevel-old-blind-mount.jpg
HHac8014 is offline   Reply With Quote
Old 12-05-2010, 01:15 PM   #2
Framing Contractor
The mounting clips that come with several new cellular blinds usually comes with two options - screw holes horizontally, or screw holes going up vertically. Seems typical of most of these clips.
* So, to get a good bite on wood, I think I need to go UP. However, our wood trim around the windows has a bevel. And I'm finding that the pre-made holes in the clips is too far out. (see pic 2)
Drill new holes closer.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 12-05-2010, 04:40 PM   #3
Seconded
mrgins is offline   Reply With Quote
Old 12-05-2010, 05:20 PM   #4
Tom Struble's Avatar
Rewards Points: 2,002
run them into the window,it won't cause any problems
Tom Struble is offline   Reply With Quote
Old 12-05-2010, 08:29 PM   #5
Considered drilling new holes - but the plastic isn't flat. It sort of bevels down to the screw holes - probably to give it additional strength. It also seems like the kind of plastic that would crack...
Tom - would that not damage the window to just go into the plastic?
Old 12-05-2010, 08:34 PM   #6
Framing Contractor
Drill from the top and down. The top has to be flat.
Joe Carola
Old 12-07-2010, 09:19 AM   #7
It would prob be ok if you use the right kind of screws and placed the brackets close to each end
Old 12-07-2010, 08:01 PM   #8
If you don't mind a bit more work then reframe and change out the old mouldings around your window.I have similar trim around my new windows.I hate it.Slowly buy surely all the trim is being replaced with nicer,more robust trim.
nel262 is offline   Reply With Quote
Old 12-07-2010, 08:47 PM   #9
pan head sheet metal screws or the screws that come with the brackets are all you need to hang those light mini blinds directly on the vinyl
damage the plastic how?
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
Window Replacement and Trim Red Truck Building & Construction 3 02-11-2010 10:13 AM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
Stool and Apron Window Trim Style Advice DIYCarp Carpentry 8 01-24-2009 09:31 AM
Double hung window trim helpless handyman Carpentry 24 04-10-2007 08:49 PM
