Window Sill Rotted - Replace Or Repair - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-04-2013, 11:13 AM   #1
Rewards Points: 172
Window Sill rotted - replace or repair
I hope this is in the right forum...
My casement window sill in the shower area of my bathroom has a little rot on it. Should the entire thing be replaced or can I fix with wood hardener and fill?
The sill is about 36" in length and about 3-4 inches of it is rotted. Just an area under the sash about 1/2' in depth and 3-4 inches long and 1/2" wide.
Thanks!
zephed666 is offline   Reply With Quote
Old 03-04-2013, 11:34 AM   #2
Rewards Points: 13,458
Best thing you could do it get rid of the window all together.
A window on a shower is just never a good idea.
Got a picture?
Old 03-04-2013, 12:17 PM   #3
Rewards Points: 172
Got a picture?
I'll post one tonight. Always had windows in every shower/bathtub where I lived...
The rest of the window is fine....
Old 03-05-2013, 08:01 AM   #4
Rewards Points: 172
Got a picture?
After a little more examination last night the window seems to be worse than I initially thought.
Rotted on the right side. The window is 33" wide. The left side is perfectly fine. There is about 9 inches of rot on the right...
Here are some photos...
Window Sill rotted - replace or repair-window1.jpg   Window Sill rotted - replace or repair-window2.jpg
Old 03-05-2013, 10:08 AM   #5
MarginallyQualified
Rewards Points: 2,464
Originally Posted by zephed666 View Post
...the window seems to be worse than I initially thought.
Rotted on the right side. The left side is perfectly fine.
The old window needs to come out completely... and the framing needs to be rebuilt. Since you're going to have to replace the exterior sheathing there as well as the tile work you may as well go the nex step and change everything else about the window while you're at it.
A single narrow casement set to the left side of that opening would work.
Old 03-05-2013, 10:25 AM   #6
What I've done a few times is removed the window and installed a Transome window and just reframed under it.
That way you still have natural light but the window now is high enough the waters not going to rot it out.
I use acrilic block, new constrution windows and all vinyl trim.
Is there at least an exhost fan in that room?
Old 03-14-2013, 12:10 PM   #7
Rewards Points: 172
I started pulling apart the window and didn;t realize that these were extension jambs that can be replaced. this is and Adersen awning window and they sell kits for replacing extension jambs. I ordered a new sash stop and stop on the right side and replaced those as well as the extension jambs.
No rot left at all and looks brand new after being stripped, primed and painted...
Old 03-14-2013, 02:49 PM   #8
747
registered
747's Avatar
Rewards Points: 534
I would recommend going with a glass block window. With 3 fins in the middle which crank out. Glass company in your area would hook you up.
747 is offline   Reply With Quote
Old 03-14-2013, 03:12 PM   #9
Rewards Points: 172
Already finished...
fixed for about $65...
rotted window sill - repair or replace caseymcdougall Building & Construction 5 08-07-2012 12:33 PM
Rotted sill plate and broken joist repair netlinks Building & Construction 6 07-17-2012 10:27 PM
Rotted Sill plate Repair Help KerryFarrell Building & Construction 2 03-16-2012 09:13 PM
Repair or Replace Garage Doors??? jbird0005 Windows and Doors 2 12-10-2011 06:42 AM
window sill repair from inside the house joshg3p0 Carpentry 3 06-10-2010 07:07 AM
