Window Sill/returns - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-27-2013, 11:44 AM   #16
Roofmaster
Rewards Points: 2,210
I dont see a problem with that, but doing it this way you may want to consider using BC or better plywood to build your box, with pine back nailers at the corners. Dont forget asphalt saturated felt between masonry and wood and insulation. Dosen't a fire egress have to be made on non combustible material though? Maybe JoeC knows.
Old 03-27-2013, 07:42 PM   #17
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,244
if the window has a slot in it to accept a jamb extension , nail the top to the two sides peices first then slip the assembly into the slot.. then fit your sil to that.. shimming it so that it is tight to the legs of the jamb.. from that you can get the length of the horns on the sil.
standard practice for all trim carpenters is to have the horn extend out 1" from the edge and face of the trim so its symetrical. also dont use cheap pine as recommded. upgrade to clear pine so you dont have to deal with knots bleeding through the paint.. the advantage of using pine compared to mdf is that if the window sweats.. gets left open during rain or for some reason the window leaks pine wont swell up like mdf does
woodworkbykirk is offline   Reply With Quote
The Following 2 Users Say Thank You to woodworkbykirk For This Useful Post:
Duckweather (03-28-2013), oh'mike (03-27-2013)
Old 03-27-2013, 09:26 PM   #18
DIY staff
Rewards Points: 7,174
You deserve two thanks for your post--Kirk---
Beepster---on those deep basement window jamb extensions---
Building it as a box is the easiest for me------you may need to test fit and tack your shims in place--
Old 03-28-2013, 03:54 PM   #19
if you build the jamb as a box theres virtually no need to use shims. if the window is installed correctly the jamb wont move.. just shoot the jamb into place then use a small flatbar to tweak the box so its stays square so your mitres will work perfect via precutting 45`s. then you just have to cut the legs to length.
ive trimmed thousands of windows this way and its pretty much flawless
Window sill/returns-227147_10151584496989466_1762770875_n.jpg   Window sill/returns-183202_10151435823869466_1264601035_n.jpg   Window sill/returns-60692_10151435823769466_590896664_n.jpg   Window sill/returns-photo877.jpg
Old 03-28-2013, 08:52 PM   #20
Rewards Points: 236
nice work, kirk
Fix'n it is offline   Reply With Quote
The Following 2 Users Say Thank You to Fix'n it For This Useful Post:
oh'mike (03-29-2013), woodworkbykirk (03-29-2013)
how to deal with a window in a shower MLMIB Kitchen & Bath Remodeling 9 09-12-2012 08:41 AM
New replacement window problems iminaquagmire Windows and Doors 7 11-11-2011 11:56 PM
Defog window recap greenmax General DIY Discussions 4 05-07-2010 05:00 PM
How to 'finish' outside of replacement window? KatieAK Building & Construction 9 04-02-2010 06:37 AM
Replace old window with smaller window Suncrest79 Building & Construction 3 04-15-2009 08:39 PM
