#1 |
window sill repair from inside the house
Some of my window sills and exterior trim have rotted likely due to a previous owner plugging up the weep holes in the triple track exterior storms. After some research, the window sill repair seems doable for me. I've only really seen info on replacing the sill from the outside of the house, but the windows in question are on the 3rd story. I have a two story colonial with a garage under, and walk-out basement in the back, property is on a slope, so the back and backsides of the house are virtually 3 stories. Can I do this type of work from inside the house? Any advice? Would I even be able to remove the triple tracks from the inside? I'm trying to avoid dying on a 40 foot extension ladder... thoughts?
#2 |
Mod
If you want a good answer, post some pictures.
Can it be done? I’ll give you a definite maybe.
A Picture Is Worth A Thousand Words Especially In The DIY Chatroom -NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State. |
#3 |
I'll have to snap a few photos tomorrow. Anyone have any thoughts in the meantime? These are double hung wood windows probably original. The house was built in the late 1960's. They have the rattling aluminum jamb liners (no pulley and weight).
#4 |
Super Moderator
I've done a bunch of these--all in the same neighbor hood--same brand of window ,too.
The bottom bit of the storm window needs to be removed. on these windows the nice rounded outside piece was still sound-- I used a router with a straight cutting bit to split the rotted window bottom--then wiggled the two halves out--leaving only a bunch of staples--I removed them with a Dremmel and a cut off wheel. All of this was done from inside.--However---the storms had a handy removable bottom. Get those pictures posted---Mike--- Last edited by oh'mike; 06-10-2010 at 03:27 PM. Reason: can't spell |
| Display Modes | |
| How to 'finish' outside of replacement window? | KatieAK | Building & Construction | 9 | 04-02-2010 07:37 AM |
| Replacement Aluminium Window - Reusing existing sill flashing? | GrantJohnson | Building & Construction | 4 | 02-10-2010 11:27 AM |
| sill plate repair over block foundation | MARLE | Building & Construction | 14 | 05-04-2009 09:03 PM |
| Crooked window sill in old wood house | bofusmosby | Carpentry | 36 | 04-13-2009 09:34 PM |
| Some walls rattle in my house if hit with something, I will explain inside posting | zincmann | Building & Construction | 4 | 11-10-2008 04:05 PM |
