#1 |
Window Sill
I want to replace an old window sill. The Plate is at an angle slanting down to the outside of the window. I used a level to find the highth of the angle at the window which is 1/4 inch. The plate mesaures 1 7/8 inches. What angle will the shim need to be to make my new sill level?
#2 |
Window Sill
You don't want the sill level, you want it to slope to the exterior to shed water.
Ron "They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." B. Franklin 1759 |
| The Following 2 Users Say Thank You to Ron6519 For This Useful Post: | Willie T (10-22-2011), woodworkbykirk (10-22-2011) |
#3 |
Super Moderator
Window Sill
Typically those are solid wood cut unto a wedge ---thickest on the inside thinnest on the outside.
I've seen those sill pieces premade of wood and white PVC-- Most times that is duplicated on site using a table saw and a sander or router.
New members: Adding your location to your profile helps in many ways.--M-- |
#4 |
Window Sill
Most of the sills I've seen are the same thickness, front to back. They have the shape of a rhombis. Basically a rectangle angled front and back to match the sill angle. Most times the bevel is between 10 and 15 degrees.
#5 | |
Super Moderator
Window SillQuote:
Good use of a big word there!!!
| The Following User Says Thank You to oh'mike For This Useful Post: | woodworkbykirk (10-22-2011) |
#6 |
Window Sill
My son would call that an S.A.T. word.
#7 |
Super Moderator
Window Sill
I never could remember names----But I draw rather well---My math teachers all hated me---
#8 |
journeyman carpenter
Window Sill
i install this type of sil all the time on siding jobs that have wood or harti plank siding.. all it requires is taking a peice of 2x3 and ripping it on a 10 degree bevel.. 15 degrees can be a bit much however. some wood siding manufacturers also make the trim that goes with their siding. the type i use actually makes sils that only require being cut to length and installed
http://www.capecodsiding.com/ |
#9 | |
Window SillQuote:
#10 |
Window Sill
the wood siding supplier i use
#11 |
Window Sill
He has a bad sill, he's not siding the house.
#12 |
Window Sill
like i said in my original post, they also make the trim that goes with the siding.. posted the site so he could see what i was talking about.. has nothign to do with the siding... just incase he doesnt have a table saw to make a custom sil to match the rest of the house
| Display Modes | |
| Window sill recess 4 a brick wall | RedBear | Building & Construction | 0 | 07-17-2011 10:53 PM |
| Window shrink film around sill? | Liv2123 | General Discussion | 4 | 01-31-2011 09:10 PM |
| my fix for rotting outside sill on wooden window | guest | General Discussion | 6 | 11-06-2010 03:58 PM |
| Problem with window and everything around it | malfunction | Building & Construction | 3 | 05-26-2009 06:11 PM |
| Crooked window sill in old wood house | bofusmosby | Carpentry | 36 | 04-13-2009 09:34 PM |
