Window Return Material - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-11-2012, 11:02 AM   #1
Rewards Points: 162
Window return material
I'm finishing off a bedroom and need to match the remainder of the house. The place has been remodeled and the window returns are pretty basic - no apron, flush 1x (i think) trim on jambs, head and sill with standard colonial casing picture framing the opening. I can only get about 5/8" thick material on the jambs because the new windows were set pretty tight in the opening and don't have much of a reveal.
I don't have access to a planer to get 1x material to the right thickness. All trim will be primed and painted white, so I have some flexibility on material choices. Has anyone successfully used MDF or maybe a high grade plywood with edge banding in this situation? Am I making things more complicated than need be and should just bite the bullet and rent a planer?
Any thoughts would be appreciated.
Some advice you receive on the internet can be worth exactly what you paid for it - be careful.
stubborn1 is offline   Reply With Quote
Old 02-11-2012, 11:09 AM   #2
Rewards Points: 13,300
How about a picture?
And where would you rent a planer?
Old 02-11-2012, 11:12 AM   #3
How deep are the jambs.
One simple way is to buy some primed baseboard and just rip it to the width you need. It's 1/2" thick already.
Old 02-11-2012, 11:25 AM   #4
Framing Contractor
Do you know someone who has a table saw?
Joe Carola
Joe Carola is offline   Reply With Quote
Old 02-11-2012, 11:37 PM   #5
Rewards Points: 162
Jambs are only about 3" deep.
I didn't think of the table saw trick - I can rip the material first, then set the blade as high as possible and make a pass on each side. Thanks for the tip.
Old 02-11-2012, 11:40 PM   #6
Why would you do it that way? Much faster by just making one cut by using the baseboard material and it will lay flat.
Old 02-12-2012, 12:47 AM   #7
Rewards Points: 2,210
1/2" mdf I would not use.
1/2" plywood with edge banding.
Or 1/2" trim (baseboard) in a wood then rip it to width as stated above.
You could use 3/4 and rip it down to 1/2" as you stated.
mae-ling is offline   Reply With Quote
Window Stool Removal Issue bperk21 Windows and Doors 4 04-21-2011 07:03 PM
Window Pane Replacement rjschwar Building & Construction 3 08-27-2010 08:15 AM
Window Replacement mark2741 Remodeling 5 07-21-2010 04:33 PM
window return in concrete block house bmancanfly Building & Construction 2 05-18-2009 08:32 AM
What roofing material is right for me? Grumpy Roofing/Siding 0 07-07-2004 08:41 PM
