Window Measurement For Shutters - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-01-2010, 07:36 AM   #1
window measurement for shutters
Im measuring for plantation shutters for my home. i am finding that the measurements for one window has a length delta of almost 1/2 inch. In other words if i measure the inner right side of the window i measured 54". Inner left 54.5". When ordering my shutters do i measure with 54" length or 54.5" length?
Please advise. I would think the obvious answer is to measure with 54" length but then im a 1/2 inch short on one side.
Any tips on how to measure windows for installing plantation shutters for inside mount?
robismyname is offline   Reply With Quote
Old 12-01-2010, 08:57 AM   #2
I assume that you are reasonably handy if you intend to install such things. What do you think about trimming shutters to fit? Do you think you would notice shutters that are slightly out of square? Do you live in some historic neigborhood where everything is already crooked, anyhow?
Are your shutters primarily going to be open or will they routinely be closed? If mostly open, I would probably opt for 54" shutters and leave as-is to avoid the out-of-square look. The 1/2" gap when occasionally closed would be no big deal to me. If the function of the shutters is a bigger priority than visual, then buy them 54-1/2 and trim to fit.
oberkc is offline   Reply With Quote
Old 12-01-2010, 11:52 AM   #3
oberkc is right. Have you considered a cardboard template when you install them?
mrgins is offline   Reply With Quote
Defog window recap greenmax General DIY Discussions 4 05-07-2010 05:00 PM
How to 'finish' outside of replacement window? KatieAK Building & Construction 9 04-02-2010 06:37 AM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
Replace old window with smaller window Suncrest79 Building & Construction 3 04-15-2009 08:39 PM
