Window Jamb Extension - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-14-2011, 08:39 AM   #1
I need help with a basement window jamb extension. The wall in front of the window appears to not be square with the window and depths range from 14 3/4 to 15 1/4. Since the depth is greater than 12", I purchased laminated pine planks that were 18" wide.
Here is my plan: Since the box needs to be square, I was planning to build it based on the largest depth at 15 1/4 and add for a 1/4 reveal all around. I was going to install and shim temporarily and then use a pencil to mark a flush line all the way around. Then, I plan to make the unit flush with the drywall by using a hand planer.
Now, is this what you would do or is there another way that I am not aware of? Should I just plane the jamb when it is attached or remove and work on it? Any help would be appreciated.
-Brent
xlr8tn is offline   Reply With Quote
Old 05-14-2011, 10:28 AM   #2
that is the way i would do it. you are gonna make the box and set it in place and mark the box all around against the wall, right. should work great.
Old 05-14-2011, 11:30 AM   #3
This sounds like it could work, but it might be more effort than you need. You could also just put each individual component up at a time and scribe them instead of building the box first, then you might have an easier time cutting the board down to fit without having to worry about clamping the entire box down and maneuvering it while planing each piece with it all still connected together. The corners might start to loosen apart unless you're planning on separating the box again after you take it out? But that would mean you'd have to but it all back together a second time and spend extra time worrying about damaging the box in the process.
Also you could freehand the scribed pieces through a table saw for a faster cut than hand planing them, or use a belt sander to quickly take the wood down and then lightly plane it after to smooth it out and make the process easier on yourself.
Dane Hitchins is offline   Reply With Quote
Old 05-14-2011, 01:32 PM   #4
Thanks all. Jamb is made and ready to scribe.
Oak casing to a vinyl jamb extension on a new window? Dustball Carpentry 13 04-14-2010 12:06 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 01:41 PM
Window Jamb Extensions Tom5151 Carpentry 27 09-25-2009 10:40 AM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
Window Jamb question groundtrac Carpentry 7 11-23-2008 09:09 PM
