Window Installation In Non Bearing Wall - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-22-2010, 07:32 PM   #1
window installation in non bearing wall
installing a 5ft x3ft steel frame window in a 2x6 non bearing wall do you need a header,
grady is offline   Reply With Quote
Old 09-22-2010, 09:37 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
yes,how do you know its not load bearing?
Tom Struble is offline   Reply With Quote
Old 09-23-2010, 07:24 AM   #3
Yes, even it is only 2x4's and cripple studs. But what he said, are you sure???
Old 09-23-2010, 03:08 PM   #4
Registered User
Rewards Points: 4,936
Is it on a gable with the roof like this? http://resourcecenter.pnl.gov/cocoon...er/article/125
Or the roof tails are overhead and some rooms above: http://www.burlington.org/Building08/Spans.pdf
Gary
Drain tile questions for retaining wall installation. Tmaxx1 Landscaping & Lawn Care 11 06-10-2011 12:17 PM
Load Bearing Wall Issue? iggy913 Building & Construction 1 07-28-2010 07:45 PM
creating door in possible load bearing wall acerunner Building & Construction 6 07-05-2010 05:33 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
Non-load bearing window header in exterior wall timelyirony Building & Construction 3 12-08-2007 05:15 PM
