Window Instalation - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-22-2011, 03:42 PM   #1
window instalation
what "type and size" of screw should i use to hang a double-hung
aluminum window ?
vsanti is offline   Reply With Quote
Old 05-22-2011, 03:48 PM   #2
Old 05-22-2011, 04:56 PM   #3
Old School
Willie T's Avatar
Your holes should already be "dimpled" for flat head screws. Choose a size that will allow the head to remain even with the surface of the window so that there is no sliding interferrence with the window action. You should try to get as long a screw as you can in that diameter. Use a bar of regular bathroom soap scraped against the threads of the screws to help them sink into the wood easier.
Willie T
Window Stool Removal Issue bperk21 Windows and Doors 4 04-21-2011 06:03 PM
Defog window recap greenmax General DIY Discussions 4 05-07-2010 05:00 PM
How to 'finish' outside of replacement window? KatieAK Building & Construction 9 04-02-2010 06:37 AM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
