Window Framing Question - Carpentry - DIY Chatroom Home Improvement Forum
Old 10-16-2010, 05:04 PM   #1
Rewards Points: 111
window framing question
I am putting a new window in where there wasn't one.
The top of the window jamb is at 79", but the height of the studs from the floor is 99". All of my framing illustrations show the header across the top, but I don't suppose I have to find a 20" 2x right? So how do I frame it? It is a load bearing wall. Window is 4' wide x 3' high.
Thanks.
Gary
wengang1 is offline   Reply With Quote
Old 10-16-2010, 06:12 PM   #2
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,342
The header size is determined by the load above it. Above the header are cripple studs that carry the load from the top plate to the header.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 10-16-2010, 08:05 PM   #3
Registered User
Rewards Points: 5,482
Three ways to do it. Clutch said one way- cripples above header. 2. cripples below header, and a 2x header for the window top. 3. Header in the floor above, useful for basement applications.Need to hang the floor joists, a lot more work.
Page 72-- diagram of Clutch's way, pp. 71-- exterior headers, built-up---- notice the number of jack studs, require bearing in floor below... http://www.ce.udel.edu/courses/CIEG4...%20-%20IBC.pdf
Gary
Door Framing Question biggidybankston Carpentry 4 12-10-2009 12:26 PM
Simple question on 16" O.C. framing TitaniumVT Building & Construction 10 11-27-2009 06:51 PM
Window Install Question Tom5151 Building & Construction 1 09-29-2009 09:34 AM
Framing and installing 5' x 6' window lanktree2005 Building & Construction 1 04-26-2009 09:21 PM
Re-sizing a window opening shtoink Carpentry 5 09-04-2008 10:47 AM
