Window/Door Casings From 1 X 4s - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-07-2010, 02:05 PM   #1
artlover13060's Avatar
Window/Door Casings from 1 X 4s
I want to use 1 X 4 whitewood to make window and door casings. The wall area around one of the doors is not level, hoizontally. If I hold the 1 X 4 flush with the flat area closest to the door, there is a gap between the 1 X 4 and the wall of about 1/2". This isn't obvious with real door casing material because it is thinner close to the door. How do I handle this problem?
Am I totally off base using 1 X 4s for casing? I like this craftsman type look, but maybe there is another material I need to use.
artlover13060 is offline   Reply With Quote
Old 01-07-2010, 03:14 PM   #2
jlhaslip's Avatar
Rewards Points: 2,188
can you post a picture? I am having trouble visualising the issue.
for example, where is this gap? between the 1 x 4 and the wall or the door jamb?
1 x 4 are fine for casing. We use it a lot around here. carve out a hollow on the back so it behaves over time.
jlhaslip is online now   Reply With Quote
Old 01-07-2010, 06:04 PM   #3
Rewards Points: 5,336
Adding a backband molding to the 1x4 will give it more character.
Ron
Old 01-07-2010, 06:22 PM   #4
I am a rank amateur and have no idea what either of you are talking about. Could you please explain what these things are and how I do this?
I will post a picture as soon as I can.
Old 01-07-2010, 06:33 PM   #5
jlhaslip's Avatar
1 x 4 will work fine.
I am suggesting that the back side of the 1 x 4 gets a cut or a couple of cuts approximately 1/3rd of the thickness of the wood to relieve the stress from the wood. Without the cuts, the wood is more prone to warping. If you have the facilities to dado out about 1/4 " deep so the middle of the back side is hollowed out would be better still.
I can't post a drawing because I am not on my regular machine.
Old 01-07-2010, 06:43 PM   #6
jlhaslip's Avatar
attempt to upload attachment...
the one on the left is a std 1 x4
the middle one shows some saw cuts
the right one shows a hollow
Old 01-07-2010, 06:47 PM   #7
that works if you're mitering corners I suspect he is square cutting everything to keep it simple
Old 01-07-2010, 07:11 PM   #8
Yes, I want square corners - no miter joints.
Jlhaslip: Thanks for the illustrations. That helps a lot.
Picture 3: would I do this with a table mounted router?
Ron - what is a backband molding?
Old 01-07-2010, 07:15 PM   #9
jlhaslip's Avatar
yes, a router table or a table saw and dado blade, but as pointed out above, any 'outside' corners would need to be mitred, or the hollow will show on the endgrain piece of your baseboard. Inside corners would be fine, if that is all you have.
Old 01-07-2010, 07:42 PM   #10
It's an "L" shaped molding that wraps around the outer edge of the 1x4's. Go to any good lumberyard and they should have it.
Ron
Old 01-07-2010, 07:46 PM   #11
I put 1x4 up in my bathroom and it's great. A picture would help come up with a solution to the problem.
pyper is offline   Reply With Quote
