Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 10-14-2009, 02:01 PM   #1
apwoodring
Default window in bathroom
I just bought a house, and it has a window above the tub in the main bath. I am going to make the tub a tub/shower combo and I was wondering how to include that window and yet keep it waterproof and from molding if I go to Lowes and buy tub surrond walls. It is already a hazy window, so privacy isn't an issue, because you already cannot see through it.
wdringap is offline   Reply With Quote
Old 10-16-2009, 05:14 PM   #2
You will need to sort through these books for the best idea, as I have never faced that problem: http://books.google.com/books?ei=8h0...indow&as_brr=3
Be safe, Gary
If you have a clothes dryer in an interior room, please check the exhaust ducting for lint build-up!
GBR in WA is offline   Reply With Quote
Old 10-16-2009, 08:44 PM   #3
If it has a sill, make sure that it angles down so water drains away from the window. Plane if necessary. You will want to caulk carefully and completely between your new walls and the frame/trim. Keep the window trim and frame painted and consider covering it with a cut down and sewn-to-fit shower curtain material to keep it from getting any more wet than it needs to. Hopefully it is high enough that it will not get drowned on a regular basis? If it is going to be in the full force of the water on a daily basis you may want to reconsider depending on the type of window and frame.
sdsester is offline   Reply With Quote
Old 10-18-2009, 11:53 PM   #4
How about a glass block window! Incorporate the blocks into the tiles.
Old 10-19-2009, 12:06 AM   #5
A "Handy Husband"
Not sure of the window type but I would replace with a vinyl window, cover the returns with cement tile backer board and tile. Slope the sill back into the shower so water does not collect on the sill.
rjniles is offline   Reply With Quote
Old 10-19-2009, 02:00 PM   #6
Hometown Exterior Designs
Glass Blocks are awesome. I absolutely love them. GBR has some good books. Look through em. ;-)
Hometown is offline   Reply With Quote
Old 10-22-2009, 12:10 AM   #7
Remodeling Contractor
Vinyl window and vinyl trim is the only way I would do it.
eisert is offline   Reply With Quote
Old 10-22-2009, 01:33 PM   #8
Household Handyman
From my point of view as a contractor who has done these: "rjniles" got straight to the first point of consideration-What type of window? Is this a wood frame window, or a metal frame window? Does it a single hung or double hung sash window? Might it be a canopy or casement window? I'm going out on a limb and say that it may be a wooden window, because you state that it is "above the tub in the main bath". This sounds typical of older homes not having a shower head in them when built. I have placed tub surrounds on tub/shower enclosures with windows in exterior walls. The surround pieces have to be cut very carefully to match up to the window trim. I have had to trim corner pieces to fit window edges to the point that the corner pieces just would not fit correctly, this was explained to the ownere before cutting. IF this is a wooden window frame, I would seriously consider replacing the window with another option before starting the project. It is going to very difficult to not have water hit any window with a shower head, and you would want to assure you will not have to replace this window soon due to water damage. Since you state that the window is hazy now, I would also recommend glass block in this area to admit light. BUT, I am one of those who like a window I can see through in a bath/shower area. It's just one of my quirks, sort of makes me feel like I'm showering outdoors. I just returned from a trip to visit my daughter and she has a vinyl clad, canopy window (swings opens upward to the outside) in her master bath, and I thought it was wonderful. Good Luck, David
More On This Topic
Bath Time Baby Toys
Bath Time Baby Toys by Expert Village
Hi, this is Daniella Buettner with the Right Start in Sherman Oaks on behalf of Expert Village. In this clip we'll be talking about bath toys. Why should play be just for outside the bath? We have many great items for the bath that will encourage the... Read More »
Hi, I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. One thing to remember when plumbing your basement, is that the location of the toilet is not as important as it first may seem. Where that pipe is sticking... Read More »
Bathroom Odor Removal
Bathroom Odor Removal by Expert Village
Hi there. Today we're talking about how to get rid of odors in your home. Let's move on to the bathroom. This is a place where a lot of odors are created. Let's take a little tour. When I go in, what you want to do is open up a window. If you have a... Read More »
Sometimes the plastic window panels decorating a wooden garage door become warped, discolored, cracked or broken. With a little elbow grease and patience, you can pry up the wooden frame around the offending window and replace the plastic with a new... Read More »
Not only is mold unsightly, it can cause health problems. Mold grows in humid or damp areas of your house and will continue to grow unless removed. After removing the mold, you can prevent it from growing back with a few simple steps. Here are a few tips... Read More »
Trailer Bathroom Window Leak sammniamii Kitchen & Bath Remodeling 0 09-30-2009 11:20 AM
Replacement Window with nailing fin mjbcable Building & Construction 0 09-15-2009 03:40 PM
bathroom window opens to another room... Jeremy Hillary Boob, PhD Building & Construction 4 08-02-2009 02:30 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 07:11 PM
That bathroom window thing... mkay2540 Kitchen & Bath Remodeling 0 05-08-2009 06:53 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
