#1 |
winder stairs.
can anyone give me some wisdom on winder stair layout? need to add a set going into a basement.
#2 |
STAFF
winder stairs.
Are you talking about full spiral stairs or stairs that make a 90° with winders? We need a little more info.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Jim |
#3 |
winder stairs.
a 90' turn...something similar to this
#4 |
Framing Contractor
winder stairs.
That is not code compliant. They can't come to a point like that. From the narrow side, the tread must be 9" deep at 12" in,
#5 |
Framing Contractor
winder stairs.
This guy doesn't care about code. He says it on the other forum. That's why he's here.
Joe Carola |
#6 |
Framing Contractor
winder stairs. |
#7 |
winder stairs.
that was just a pic example i found on the net, i'm looking for help in designing, laying out a set of these... at around a 36" +- width... someone must be familiar with building these they were quite poplular in older homes
#8 | |
Framing Contractor
winder stairs.Quote:
Everyone is familiar with them and building them to code. Problem with you is that you said on the other forum...you're not doing them to code. So why do you keep asking about them?
Joe Carola |
#9 |
winder stairs.
3 winder stairs are code compliant where i am. so if u can help with the layout why dont you?
#10 | |
Framing Contractor
Because on Contractor Talk forum you said code wasn't an issue and you no one agreed and wouldn't respond. Now you come here and say code is an issue because your not getting any answers. Good luck.
Joe Carola |
| The Following User Says Thank You to Joe Carola For This Useful Post: | woodworkbykirk (11-09-2011) |
#11 |
Moderator
winder stairs.
R311.7.4.2 Tread depth. The minimum tread depth shall be 10 inches (254 mm). The tread depth shall be measured horizontally between the vertical planes of the foremost projection of adjacent treads and at a right angle to the tread's leading edge. The greatest tread depth within any flight of stairs shall not exceed the smallest by more than 3/8 inch (9.5 mm). Consistently shaped winders at the walkline shall be allowed within the same flight of stairs as rectangular treads and do not have to be within 3/8 inch (9.5 mm) of the rectangular tread depth.
Winder treads shall have a minimum tread depth of 10 inches (254 mm) measured between the vertical planes of the foremost projection of adjacent treads at the intersections with the walkline. Winder treads shall have a minimum tread depth of 6 inches (152mm) at any point within the clear width of the stair. Within any flight of stairs, the largest winder tread depth at the walkline shall not exceed the smallest winder tread by more than 3/8 inch (9.5 mm). From: http://publicecodes.citation.com/ico...011_par011.htm Move around on that site with the "previous section/ next section" buttons for more info. Gary
Clothes taking longer to dry?
Clean the dryer screen in HOT water if using fabric softener sheets. They leave a residue that impedes air-flow, costing you money. Clean the ducting in the last six months? 17,000 dryer fires annually! |
#12 |
Stairguy
winder stairs.
One way to do it is frame a series of boxes on top of each other.the straight section can be framed conventionally. Find out what your rise is and do a layout on the wall first.
#13 |
winder stairs.
my total rise is 97 1/2" what i've come up with is 11 runs 12 rises at 8 1/8th a bit high maybe but i have limited head room to deal with if i go beyond 11 otreads
#14 |
STAFF
winder stairs.
If you didn't have problems with your head room it would be 13 risers at 7 1/2 inches. I don't know what your run is so I can say there other than code width of the treads.
#15 | |
run is around 113" b4 i run into headroom issues.. i'm messing with different layouts for the winders, have a 36" square and a 40" square layed out now trying to figure out my best options |
| Display Modes | |
| Questions about building stairs. | cvriv.charles | Building & Construction | 7 | 12-19-2012 05:04 PM |
| Kite winder for stairs | ianc435 | Carpentry | 18 | 11-05-2010 12:26 AM |
| Help with staining my stairs | kimber | Flooring | 2 | 12-04-2009 08:45 PM |
| Strengthening stairs with less support | HitLines | Remodeling | 1 | 10-30-2009 12:45 AM |
| Painted the stairs ... . | kimber | Painting | 8 | 10-07-2009 12:50 PM |
