Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 10-07-2005, 02:54 PM   #16
Will this work?
Just read the same question in Contractor Talk Forums.
It was an interesting subject, but I'm out!
"freind of a freind will do some reinforcing" "strongbacks" "adding uprights"
The solid and professional advice in response to the question came from Mighty Anvil with whom I have to agree....and also led to a bit of freindly banter with hammerslammer.
'Andyman is offline   Reply With Quote
Old 10-07-2005, 06:49 PM   #17
Will this work?
Wreckless, you need to toughen up and try thank you more often. Mightyanvil out.
mighty anvil is offline   Reply With Quote
Old 10-15-2005, 04:52 PM   #18
Will this work?
UPDATE:
Just wanted to put an update up of the finished setup. I put vertical 2X6 supports running from the lower cord to the upper cord of the rafters. Then I added straps, which should help distribute the weight over 5 points and not just everything on the winch. I then raise the ski enough to get the straps under it, then I lower 50% of its weight on the straps. Now I just need to copy this setup for the other ski and hang it right next to this one, park the boat underneath it and I am ready for winter..
wreckless123 is offline   Reply With Quote
Pay GC to construct home and finish it myself? L O N G . . . Badfish740 Off Topic 9 07-27-2007 09:44 AM
Am I being overcharged for general construction work? baloney12 Building & Construction 2 07-11-2007 07:09 PM
Modifying existing duct work Thurgee HVAC 3 04-05-2007 10:35 AM
is this bad tiling work? garrick Flooring 17 09-27-2006 01:30 AM
