Will My Pergola Beam Sag? - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-06-2011, 09:01 PM   #1
Hey Guys,
I'm looking to build a Pergola frame (no rafter or purlins) around my fire pit. I'd like one of the sides to span 18' using a 2X10X20. Will I run into issues with this saging or twisting down the road? I could use cross pieces on top to join the two 2X10X20 together if needed to stop flex/twisting. I guess my biggest conern is saging.
Also what type of footing would you recommend for the 6X6 (I like the larger post look vs a 4x4) posts? Some say a concrete footing with a simpson anchor, others say to put the beam in concrete directly in the hole. The beams will be surrounded by a paver patio and also have 3x2 columns (each side) built on the bottom for looks, so water isnt going to be an issue. I could use copper bands at the footing and where the column cap will meet the 6x6 if needed
What do you recommend?
ErikU19 is offline   Reply With Quote
Old 04-06-2011, 10:50 PM   #2
By the way I am in Houston, Texas.
Old 04-06-2011, 11:57 PM   #3
Rewards Points: 5,336
If you're using pressure treated, #2 grade southern yellow pine, you'll need 2x12 to span 18 feet.
I would design it so the span was reduced.
Ron
Old 04-07-2011, 01:53 AM   #4
Residential Designer
AndyGump's Avatar
Rewards Points: 664
Send a message via Skype™ to AndyGump
Ron
Hey Ron, how did you figure that one? Even with a live load, of which there is none, of 10 lbs. and assuming a dead load of 10 lbs. I came up with a span of over 23'.
Thank you sir.
Andy.
AndyGump is offline   Reply With Quote
Old 04-07-2011, 08:31 AM   #5
Civil Engineer
Rewards Points: 4,576
If I understand you correctly, you want to build a frame but no roof. Unless you are planning to support something on top of the joists, the only load will be the weight of the joist itself. But maybe I don't understand what you are proposing.
If there is no live load, weight only, the issue will not be sag, but twist of the wood as it dries. Very hard to get PT lumber that is dry, it is usually at least 30 percent moisture content, and it is likely to twist and bend as it dries. If this is aesthetically unacceptable, you need to get LVL or microlam, not for strength, but to resist twist.
As for the footings, you live in Houston, famous for expansive clay soil, which is a real problem for shallow footings. You should check with your local building inspector, they may have some suggestions for low load footers to minimize soil movement.
Daniel Holzman is online now   Reply With Quote
Old 04-07-2011, 08:48 AM   #6
AndyGump's Avatar
Rewards Points: 664
I looked up a few things regarding your area and it seems to me that for this project (if I understand the scope) you may not need a permit.
I would look into cedar and footings of 12" dia. sono-tubes about 24" min. deep would work fine.
Lots of other details too but that is a start.
Andy.
Old 04-07-2011, 10:28 AM   #7
Thank you sir.
Andy.
I looked it up in a span table.
Ron
Old 04-07-2011, 10:27 PM   #8
Thanks for the input guys!
There is no load on the pergola besides the weight of the frame itself, in this case (2) 2X10X20 on each side (the long spans). The shorter spans will use (2) 2X10X16 cut to lenght. that's it.
I can get blue linx 2.0E LVL for $50 (2X10X20) if that would be a better option? I plan on coating the entire structure with an exterior finish in a cedar color to protect it (and for looks), so if it isnt treated wood it isnt a huge deal.
I also could move up to 2X12 if needed?
Old 04-16-2011, 12:27 PM   #9
I did a pergola with a 16' span with 2x6's a while back and used douglas fir. I only got warping in one piece but was able to bend it back and fasten it. I t looks fine.
rtibbs4 is offline   Reply With Quote
Old 04-16-2011, 12:51 PM   #10
Too Short? Cut it Again!
Missed the opening post. No comment.
How to repair main support beam Jerry48ece Building & Construction 0 01-08-2011 09:38 PM
Pergola construction - beam span without sagging fahartle Building & Construction 9 07-25-2010 08:54 PM
Crawl Space Beam and Joist Support Questions Fire4Effect Building & Construction 5 06-28-2009 02:07 PM
beam for pergola woodsglen Building & Construction 4 04-11-2008 08:55 PM
A Beam for a Pergola rv8tor Carpentry 18 10-30-2007 01:01 PM
