Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 10-27-2009, 03:50 PM   #1
Default Why won't interior doors shut anymore?
So I had new pre hung doors installed throughout my house. Been in for over a week and all shut fine into jambs. Took em down and replaced hinges with a different finish. Now the doors won't shut. They all seem to get caught up on the hinge side before door gets into jamb. Doesn't seem to be hitting anywhere. Any ideas?
Mike2181 is offline   Reply With Quote
Old 10-27-2009, 03:57 PM   #2
contractor
are the hinges installed backwards? would cause the door to "bind" before it closed all the way.
Meetre is offline   Reply With Quote
Old 10-27-2009, 05:29 PM   #3
Anytime you change hinge leafs or sets, the reveal will change from the hinges you initially set the door to. Hinges are manufactured slightly different from each other, especially at the pin area. When painting doors be sure to install the hinges exactly the same, even the pins change on older work. You can bend the barrels to adjust the reveals, either way that is necessary. You can also set the leaf deeper on one edge or the other to put a cant to it.
Be safe, Gary
If you have a clothes dryer in an interior room, please check the exhaust ducting for lint build-up!
GBR in WA is offline   Reply With Quote
Old 10-27-2009, 06:54 PM   #4
Thanks for the quick replies guys. Will stop off and take a look at the doors tonight after work. Was wondering myself if it's possible for them to be installed backwards..... figured I was fishing for an easy answer.
More On This Topic
Candles add a nice touch to your dinner table, mantle or holiday decor. However, candles can do more than just look pretty. Here are some ideas for using your candles in a variety of ways. Read More »
Now doing wood working for so many years, chisels have been a very big part of the construction industry. It all depends on what you're building, there are so many different styles, shapes and uses of chisels. Me using chisels on a job site, I would use... Read More »
A scissor jack is a primary tool used when changing motorcycle tires; learn how to use one in this video on DIY motorcycle maintenance for flat tires. Read More »
Hi, this is Sean Hobson. Right now we're working with the motion offense. We're going to show you a little bit of a back door cut style that you can work with this motion offense. This is was made famous by Princeton and now used by Georgetown a lot... Read More »
Ok, so, now all we have left to do, is get our bottom board in. And, what we'll do is, we'll just take this whole door off, see if that will give us enough room, for this to slide in. (Cough) Excuse me. Now, put our hinges back on. And, there we go. OK... Read More »
I still hear water running when I shut off the main water shut off valve jnut Plumbing 6 07-15-2009 09:46 AM
Shut Off Valve won't shut off DIY_Dumbie Plumbing 1 07-11-2009 04:22 PM
Community water shut off zevon Plumbing 14 10-03-2008 09:16 AM
Toilet to Go won't shut off Evildad Plumbing 4 09-28-2008 02:26 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 01:16 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
