Who Carries 1 1/2" Floor Boards? - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-18-2009, 04:16 PM   #1
Who carries 1 1/2" floor boards?
I'm seeking a distributor or retailer that carries 1 1/2" floor boards. The house is from 1940 and has thin floorboards throughout the house. I need to fill in two separate areas that are damaged: one board wide and about 8" long. I can't seem to find any floor boards less than 2" wide. Anybody know where I can find them? I finally found one company willing to send me a sample that would do the job, but I lost their website address.
Thank you.
Jeanette Oki is offline   Reply With Quote
Old 01-18-2009, 09:47 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
i shouldn't be too hard to mill a couple of wider pcs for what you need.
just leave the tongue rip it to width and cut a rabbet on the other edge
to clear the tongue of the existing floor nail it down then fill the nail holes
Tom Struble is offline   Reply With Quote
Old 01-20-2009, 05:43 PM   #3
Rewards Points: 5,336
The stated width of 1 1/2" is a standard flooring width you should be able to find at any flooring distributor. The ."really thin" description is unclear. Flooring has width and thickness dimensions which need to be expressed in numerical sizes.
Ron
Old 01-21-2009, 05:56 AM   #4
Home Improvment Contactor
Some people will remove the pieces they need from a closet or some place that has been carpeted. Then patch that floor.
Jack of most is offline   Reply With Quote
Changing from 1 1/2" PVC to 2 1/2" PVC DLHC40 Plumbing 4 06-30-2008 10:39 AM
Framing Question: How thick the wall that carries plumbing? jaes Carpentry 5 06-18-2008 05:39 PM
How many wires in 1/2" conduit? alvanos Electrical 17 02-26-2008 03:37 PM
1/4" or 1/2" cement board? kemerick Flooring 4 09-14-2007 11:42 AM
How to outline the 1 1/2" PVC drain froddan Plumbing 6 07-24-2007 03:15 AM
