White Cedar Shingle Siding On Shed? - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-22-2010, 11:41 AM   #1
Rewards Points: 16
White Cedar Shingle siding on shed?
Hi,
I'm building a 10x14 storage shed using platform / stick-built techniques, and want to side it with white cedar shingles. I plan to use 4d SS ring-shank nails. Wall sheathing 1/2" CDX ply. Would appreciate your advice:
With no interior walls, the points of the shingle nails will stick thru the sheathing. What's the best way to avoid drawing blood when stowing garden tools hung on inside walls?
  • Clip the points flush with the ply?
  • Clinch them (bend points with hammer)? Will stainless nails tolerate?
  • Or glue up rigid foam insulation panels to hide the points?
Thanks for your help!
FWEhr is offline   Reply With Quote
Old 08-22-2010, 01:11 PM   #2
Civil Engineer
Rewards Points: 4,790
If you can't get shorter nails, you might try grinding the point flush with the wood using a circular grinding attachment that can go on a drill. I do this all the time when I need to eliminate a sharps hazard.
Old 08-22-2010, 01:54 PM   #3
Rewards Points: 5,336
Originally Posted by FWEhr View Post
Hi,
I'd eliminate the issue and use 3/4" sheathing.
Ron
Old 08-22-2010, 04:58 PM   #4
kwikfishron's Avatar
Rewards Points: 618
7/16” crown staple gun with 1 1/8 - 1 1/4” SS staples.
Staples hold shingles better anyway because the staple crown bridges over and holds down the grain of the wood.
Use the nails for under any windows and your last coarse.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
Tom Struble (08-22-2010)
Repairing some cedar siding, shingle style creamaster Carpentry 14 07-25-2011 03:35 PM
Installing fiber cement siding over existing cedar siding heron Remodeling 3 07-24-2009 11:17 PM
Sealing Cedar Siding rocketdoctor Painting 5 06-25-2009 06:53 AM
Replacing Asphalt w/ Cedar Shingle pbehnke Roofing/Siding 1 05-06-2008 01:28 PM
is an attic vent required for cedar shingle roof? walenta Building & Construction 2 10-25-2007 10:31 AM
