Where Can I Find These Drawer Glides? - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-11-2013, 04:32 PM   #1
Rewards Points: 578
Where can i find these drawer glides?
In my kitchen, we are putting pullouts in all of the cabinets. I despise getting on my hands and knees and crawling into a cabinet to retrieve something in the back, so this will cure my problem.
HD and Lowes in my area do not carry them.
Also, how much weight can be put in one of these pullouts before the drawer glide no longer works properly? I am planning to put my china inside one of these pullouts, and its very heavy.
Where can i find these drawer glides?-kitchen-islad-pull-out-drawers-01a.jpg   Where can i find these drawer glides?-pull-out-shelves.jpg
Come and see the progress on my mobile home paradise!!! (NEW PICS ADDED ON 01/26/15!!)
http://www.diychatroom.com/f49/compl...emodel-168570/
TrailerParadise is offline   Reply With Quote
Old 03-11-2013, 04:47 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 820
Lots of places to order them from.....
Rockler.com has a great selection.....and they carry some full extension slides that will carry up to 100 lbs....
There are also some places you can order prefab drawers from....I do woodworking as a hobby....I don't do drawers any more...just cheaper to by them and the doors....
Old 03-11-2013, 05:06 PM   #3
Rewards Points: 578
Okay, so if i order 24" glides, does that mean that the glide will be 24" fully extended? Or 24" when closed? My cabinets are 23" deep, so if i put a 24" glide on it, but the glide only opens to a width of 24", it wont extend all the way out, will it?
Sorry i am totally confused
Old 03-11-2013, 05:09 PM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 820
Yes...and no.....and yes....and no, depending on the slide....
Go to the rocker site....key words...."full extension"....some actually come out further than the depth of the drawer....
Just remember...there tends to be a direct correlation between slide distance and $$....
Old 03-11-2013, 05:11 PM   #5
Rewards Points: 578
i did search for full extension, but i need to know if the glide marked 24" is 24" when fully open, or fully closed. If its 24" closed, itll work. If its 24" open, it wont.
Old 03-11-2013, 05:15 PM   #6
JOATMON
ddawg16's Avatar
Rewards Points: 820
All you had to do was select one of the slides and click on the link for the data sheet....
http://www.rockler.com/tech/RTD10000090AA.pdf
The Following User Says Thank You to ddawg16 For This Useful Post:
GBrackins (03-11-2013)
Old 03-11-2013, 05:22 PM   #7
Rewards Points: 578
Thanks! I found exactly what i needed. Now i just need to figure out how many drawers per cabinet, and we're good! Thanks for your help!
Can't find good laminate comparison anywhere cpsilo1 Flooring 3 03-20-2011 05:49 PM
Need to find very low profile kitchen drawer hardware galmoughraby Interior Decorating 1 01-10-2011 01:58 PM
Need help to find suitable product! SoFF-OnE General DIY Discussions 5 12-21-2010 09:39 PM
Kitchen drawer joint part chulheekim General DIY Discussions 9 12-11-2010 12:15 AM
Where can I find good contractor and building material suppliers? denniis Off Topic 5 03-10-2009 10:27 AM
