When Are Nails Better Than Screws? - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-17-2013, 09:58 PM   #1
Lord of Slums
Rewards Points: 1,974
When are nails better than screws?
I have to re-secure some 3/4 inch cedar siding to 2x4 wall studs. I am thinking of nailing the siding with ring shank because I fear deck screws will split the clapboard siding. The siding is 50 years old, has a 6 inch exposure and is face nailed.
mj12 is offline   Reply With Quote
Old 05-17-2013, 10:10 PM   #2
Rewards Points: 13,450
Use stainless steel siding nails.
http://www.bing.com/images/search?q=...ectedIndex=103
Steel or galvinized with turn the wood black.
woodworkbykirk (05-18-2013)
Old 05-18-2013, 08:23 AM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,114
joes right, the reason for using stainless is do to the oils in the cedar it reacts with galvanized nails
woodworkbykirk is offline   Reply With Quote
Old 05-18-2013, 09:45 AM   #4
Roofmaster
Rewards Points: 2,172
Pre-drill if you dont want it to split.
Old 05-19-2013, 05:58 PM   #5
Lord of Slums
Many of the nail heads I see are black, so Yes Joe is right... .....
All those nails and screws dougp23 General DIY Discussions 18 03-21-2012 02:31 PM
Screws or nails in dbl layer of OSB soggycashew General DIY Discussions 6 02-18-2012 01:38 PM
Drywall nail types kevsprojects Drywall & Plaster 23 07-31-2011 07:34 PM
What nails to use? 2x4 framing, osb sheathing jw15842 Carpentry 6 09-08-2008 10:31 PM
DECK decking nails vs screws ... christian15213 Building & Construction 8 05-02-2005 07:51 PM
