When To Change Blade? - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-10-2014, 11:15 AM   #1
Rewards Points: 170
When to change blade?
My miter saw seems to be leaving shreds on the bottom and back side when I cut lately. Is that a clear cut sign it is time to change the blade? Can't remember when/if I have changed it, but I have cut all sorts of stock with that blade from wood, composite, to pvc piping on occasion.
HandyFrank is offline   Reply With Quote
Old 01-10-2014, 11:26 AM   #2
Rewards Points: 12,868
Composites and PVC are really hard on blades and can leave a sticky film from the melted plastic.
Run your finger over the edges of the teeth, are they starting to round over?
Motor sound like it's struggling when cutting?
Old 01-10-2014, 01:08 PM   #3
Rewards Points: 444
The advise given to me once by an old time cabinet maker was to drag your thumb nail across the point of a tooth with a little (subjective) pressure. If it won't leave a scratch mark have it serviced or replaced.
Old 01-10-2014, 03:17 PM   #4
Rewards Points: 170
Thanks for the tips guys. Going to feel it and see later tonight. Is it worth having a blade sharpened these days? I see a combo pack of 2-10" Dewalt blades for $35 on Amazon, or a Diablo for $36.
What is a good tooth count for general all around work? I'll look and see how many teeth the blade on there has now, but figured I'd ask as a reference.
Old 01-10-2014, 03:59 PM   #5
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,006
get some blade cleaner first and clean the residue off the blade, that will extend the life of the blade quite a bit
as for sharpening blades.. cheaper blades shouldnt be resharpened,, theres very little carbide on them.. the dewalt blades fit this description. freud diablo blades are made so they can be resharpened and are better than the dewalt ones to begin with
woodworkbykirk is offline   Reply With Quote
The Following 3 Users Say Thank You to woodworkbykirk For This Useful Post:
BigJim (01-12-2014), DH558 (01-29-2014), eandjsdad (01-12-2014)
Old 01-11-2014, 09:24 PM   #6
Rewards Points: 170
go with the Freud (Diablo) blades. I currently own a Dewalt miter saw and it has the factory Dewalt blade on it (same ones as the combo packs) and it is already dull (the saw is bout 5 months old with medium use) from what I hear the diablo blades are amazing
diyer111 is offline   Reply With Quote
Old 01-11-2014, 10:07 PM   #7
chitownken's Avatar
Rewards Points: 510
Really like the Freud and the CMT Orange blades. About the only things I would use the DeWalt blade for is rough framing and maybe pressure treated. Buy the Freud.
60 or 80 tooth.
chitownken is offline   Reply With Quote
Old 01-12-2014, 12:59 AM   #8
Rewards Points: 170
Thanks guys,
I'll try a quick clean, but its probably time for a blade. If I think back the saw was given to me and used for a bit, and I've used it over the last few years to cut all sorts of stuff. Lots of clean cuts along the way, but slowly has been fraying the back side.
Saw the Diablo 50 and 60 tooth blade today at Home Depot, and Amazon has the 40,50,60, and 80 tooth. Seems like the 50 tooth is called a combination where the 60 is for fine work. In all honesty I don't want to have to change the blade a lot, so would the 50 be a better option to use and go slow with nice trim, and allow me to chop 2X4's for unfinished work when needed?
I put a nice blade on my table saw, think it was this one:
Freud LU83R010
But again I don't want to be swaping blades, so what is a good all around blade for the chop saw that will do fine work some days, and rough work the next? Combination 50? The project I have up right now is going to be board and batten wainscoting type work, so definitely on the more finished end.
Old 01-12-2014, 02:45 AM   #9
JOATMON
ddawg16's Avatar
Rewards Points: 836
You quickly learn that $30-50 for a blade is cheap.
Believe it or not, I've had good luck with Ryobi blades. But you won't go wrong with a Diablo...
Also....make sure your using the right blade....for hardwood final cuts, I use a 60 tooth blade. The same blade works well with Melamine.
ddawg16 is online now   Reply With Quote
Old 01-12-2014, 08:48 AM   #10
Ole Wood Worker
BigJim's Avatar
Rewards Points: 118
With Melamine you will need a negative hook blade to keep from chipping and then you will have to cut slow and hope for the best.
Watch out when cutting melamine, the edges will cut you, they are very sharp.
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
Old 01-12-2014, 08:54 AM   #11
chitownken's Avatar
Rewards Points: 510
Combination blades are a compromise and as such are not the best for anything. Not fast for rough framing, not the smoothest for finish work. I usually have a 60 tooth on the miter saw and just put up with slower cuts in rough framing. For finish work I usually swap in the 80.
If you are not doing much trim or cabinetry work, the 50 will probably work OK for you. If the majority of the cuts are for finish wirk, get the 60.
Old 01-12-2014, 09:51 AM   #12
Ole Wood Worker
BigJim's Avatar
Rewards Points: 118
On a table saw they are, the combination rip/crosscut is my favorite blade. Use to CMT made a great blade so did Amana not now days though, I don't think Forest even makes a combination blade now, if they did that would be the blade to have on a table saw. I wouldn't use the combo blade on a miter saw, don't know if they even make a 12 inch combo or not.
The more teeth the hotter the blade will get, heat kills carbide.
Jim
oh'mike (01-12-2014)
Old 01-12-2014, 10:02 AM   #13
DIY staff
Rewards Points: 7,174
We are talking about chop saws---so cross cut blades are used----
Those should not be used in a table saw---Jim is correct---use a combination blade or a dedicated ripping blade in a table saw----more teeth is not better for ripping--
Down right dangerous at times.
The Following 4 Users Say Thank You to oh'mike For This Useful Post:
BigJim (01-12-2014), ddawg16 (01-12-2014), eandjsdad (01-12-2014), Maintenance 6 (01-13-2014)
Old 01-13-2014, 02:11 PM   #14
Mold!! Let's kill it!
Rewards Points: 2,012
Here's a link to a nice guide from CMT on saw blade aplications, tooth grinds, etc.
http://www.cmtutensili.com/media/Fil..._usa-chart.pdf
The Following User Says Thank You to Maintenance 6 For This Useful Post:
oh'mike (01-13-2014)
Circular saw blade sharpening Dave88LX Tools 11 10-29-2013 04:13 PM
How to change shredder blade? mntentman Landscaping & Lawn Care 5 10-31-2010 09:31 PM
Saw blade recommendations for ripping prefinished wood benjamincall Carpentry 17 03-08-2010 01:55 PM
IKEA Cabinets and a good saw blade (my experience) DIYatHome Kitchen & Bath Remodeling 0 12-13-2009 08:32 PM
Best blade for circular saw to cut multiple layers. Clutchcargo Building & Construction 5 12-02-2009 08:27 PM
