What's The Purpose Of The Hollow Recess Behind Base Moulding? - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-04-2013, 05:47 PM   #1
Rewards Points: 452
What's the purpose of the hollow recess behind base moulding?
I've cracked base moulding multiple times when nailing because of this recess caving in.
what's the purpose of it?
pman6 is offline   Reply With Quote
Old 03-04-2013, 06:11 PM   #2
Rewards Points: 12,878
Base only needs to make full contact at the top and bottom, by having that gap the piece can span any flaws on the wall or make up for any cupping in the base.
Your not suppost to be nailing in the middle of baseboard.
Use a finish nailer and it will be 10 times faster and no splits.
Old 03-04-2013, 06:41 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,006
exactly, its the same thing with door jamb stock and hardwood flooring
woodworkbykirk is offline   Reply With Quote
Old 03-05-2013, 02:17 PM   #4
Mold!! Let's kill it!
Rewards Points: 2,012
It's there so that if the piece decides it wants to cup, the edges won't pull away from the wall.
Old 03-06-2013, 09:11 PM   #5
Rewards Points: 1,450
It's there to aggravate DIY'ers....
ktkelly is offline   Reply With Quote
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 10:10 AM
Bullnose Base Moulding Install Rick5472 Carpentry 16 09-21-2009 10:44 AM
How to create a curved wooden base shoe? hayzen Carpentry 3 07-28-2009 04:29 PM
Pergo and Base Moulding jsr0103 Flooring 1 09-16-2008 07:52 PM
Base molding or carpet first??? Dan N Flooring 5 02-01-2007 09:29 AM
