What Would You Do Here? - Bathroom Mouldings - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-28-2013, 07:15 PM   #1
Rewards Points: 169
What would you do here? - Bathroom Mouldings
There was a glass door on the shower/tub, which we didn't like at all. We removed it, but we're not really sure how to blend the tiles into the wall. Any ideas?
RCGA is offline   Reply With Quote
Old 03-28-2013, 07:47 PM   #2
Rewards Points: 636
use bull nose or a trim tile
http://www.homedepot.com/Flooring-Ti...z140hb=1z140hb
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 04-04-2013, 09:34 PM   #3
Rewards Points: 87
What I would do which would make a much better looking job is this:
I would build this part of the wall that is set back outward so I could go
across it evenly with the tile. This would make a very good looking finished
job and it would not look like it is remodeled. It will just look like this was
always 1 straight wall.
Do you have anything behind this? Did you remove the shower or what kind
of glass door was it.
Did you remove the tub as well? If you did you are leaving a lot of unused space. You could put shelves or even a closet there.
TGMcCallie is offline   Reply With Quote
Old 04-04-2013, 10:19 PM   #4
Rewards Points: 744
Sure, if he/she can find the same tile. And hopefully, there's not a door on that wall, else the door frame/jamb would also need to be built out.
I'd either use a wood or poly molding or bullnose tile.
What are you planning to do above the tile? I'd replace that wood with drywall, primed and painted.
Seattle2k is offline   Reply With Quote
Old 04-04-2013, 10:28 PM   #5
Rewards Points: 87
Yeah, I would replace with Drywall and bring it out even. An offset like that is going to be not too pleasant to the eye. I would even do that and replace all the tile because even if you can find the same tile it will not be the same color unless it was from the same batch. Believe me I know because I did not get enough of floor tile to do my sunroom and kitchen and when I got more it was shades different in color. I luckily had not installed it so I took all of it back and got all tile from the same batch number.
I guess we learn as we go along.
Old 04-05-2013, 09:22 AM   #6
Roofmaster
Rewards Points: 2,210
I would extend the tile out another foot or so. Looks like a pretty narrow shower area. Get rid of that wood, replae with wonderboard. Wood will twist and shout up there.
Old 04-05-2013, 10:48 AM   #7
Roofmaster
To be honest, I would rip out that tile, rip out that window and remodel the bathroom. I did not see the window in the shower before. Tile is really not too expensive. Best Bang for your buck.
Best option for Bathroom Ceiling Paint? tealab Painting 7 04-05-2013 04:49 PM
Columbus Ohio Basement Full Bathroom -Post-Construction Compliance Hermi14 Plumbing 5 03-12-2013 07:11 PM
Rewiring Bathroom & Den heyjoe91 Electrical 4 02-21-2013 04:22 PM
Exhaust Vents - Bathroom and Stove trophywalleye HVAC 0 03-19-2011 10:14 PM
How to select appropriate Bathroom Lighting crescentharbor1 Kitchen & Bath Remodeling 1 02-28-2011 09:47 PM
