What Would You Do? Fireplace Ideas - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-03-2011, 10:03 PM   #1
highlift's Avatar
What would you do? fireplace ideas
hi all!
i will be laying a hearthstone and putting up tile on the walls. thats a very broad statement, i know
i have some ideas of what i would like to do and how to do it. unfortunately with the cold weather around the corner, i'd like this to be a relatively quick project so i can start using the fireplace.
what type of material should i use for the hearthstone? how should i lay it and attach it? i like the look of glass tiles. im not interested in traditional wood surrounds. would like a single shelf mantle.
so, what would you do if this was your fireplace?
i'd love to hear some ideas from anyone.
http://www.flickr.com/photos/12755532@N05/6311014642/
http://www.flickr.com/photos/12755532@N05/6311014450/
highlift is offline   Reply With Quote
Old 11-04-2011, 12:04 AM   #2
here is what i did
we found the marble tile at the bargain outlet. for a simple shelf just make something like the top of mine
What would you do? fireplace ideas-p1050459s.jpg   What would you do? fireplace ideas-p1050274s.jpg
The Following User Says Thank You to DannyT For This Useful Post:
highlift (11-04-2011)
Old 11-04-2011, 01:41 PM   #3
highlift's Avatar
that looks fantastic! and the floors look great too
is that one piece of marble for the hearth? any insight on how i should attach a large piece of stone to my concrete slab foundation?
Old 11-04-2011, 11:38 PM   #4
was quite a change from what was there. they are just 12"x12" marble tile. We didnt like the looks of the old mantle and tile. was the first thing I replaced after we moved in.
the floor is brazillian tigerwood that I put down and finished myself. if you do a slab you could probably set in in thinset. hopefully someone that does that will come along. I used cement board and thinset for mine but I have wood subfloor.
Old 11-05-2011, 06:53 AM   #5
If you are putting the hearth directly on the concrete slab than all you would need is thin set. If you have a basement or wood where the hearth would go you will need a concrete board. Hope that helps.
Kader516 is offline   Reply With Quote
Fireplace shelving ideas anyone?? Daddyshammer Carpentry 16 06-01-2011 09:43 PM
Need some ideas how to update this fireplace acerunner Building & Construction 1 03-11-2011 08:32 AM
Basement Fireplace Ideas DAdams982 Remodeling 6 01-28-2011 01:35 PM
Glass mirror over fireplace, any ideas how to install flat screen TV? dynamo Building & Construction 1 07-25-2009 10:02 AM
Fireplace wall ideas Davidb6 Carpentry 12 02-02-2009 06:02 PM
