What Would You Call This? - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-25-2012, 01:10 AM   #16
Rewards Points: 502
Originally Posted by homesower View Post
That is a stretcher bond, also known as a running bond. They modify if further based on the overlap, so this would be a 3/4 running bond.
Since it doesn't have any bricks running sideways to tie it into another layer of brick it suggests that it is just a veneer. There is usually a cavity between it and whatever it is anchored too, so it is also called a cavity wall.
Thanks for that. (it must result in a lot of brick-cutting at the corners!).
tony.g is offline   Reply With Quote
Old 05-04-2012, 02:22 PM   #17
Retired Cabinetmaker
woody4249's Avatar
Rewards Points: 156
[quote=homesower;904776]I understand the problem. Long areas of blank wall look wrong. Wrong, wrong, wrong.
I am going to suggest some additional solutions. 1) A big tall bush 2) a trellis with vines, roses or an espaliered fruit tree or something along the line of a 4) tresllisted arbor, with a park bench or swing underneath it.
I was thinking something along the same lines.......a plastic gnome maybe ?
What about a life size Elvis?
woody4249 is offline   Reply With Quote
Old 05-04-2012, 05:56 PM   #18
I'd go with brickmould. Btw, I don't like the idea of large bushes or small trees next to the foundation, but a trellis is a good idea
mrgins is offline   Reply With Quote
Old 05-31-2012, 04:30 PM   #19
Rewards Points: 308
Got around today to fix this problem. Got the pair of shutters new at the Restore for $8 and the baseboard trim pieces from a wholesale store also for $8. Cut and nailed the trim, caulked the edges, and this is what I got -- not bad for under $20.
The plan is to get some shutter hinges and S hooks to make it appear more legitimate, and to maybe add a window box with some greenery to soften it a bit. Any other suggestions?
smokey847 is offline   Reply With Quote
When do I call the plumber? ctote Plumbing 4 07-07-2011 11:28 AM
Contractors Venting Thread. Long. Doc Holliday Off Topic 7 05-23-2011 09:18 AM
Call the Greene County Sheriffs Dept. Roofmaster417 Off Topic 0 04-29-2011 09:55 PM
What to do? Who to call? Dusty General DIY Discussions 1 06-07-2007 03:58 AM
