What Would You Call This? - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-04-2012, 04:17 PM   #1
Rewards Points: 308
What would you call this?
Looking to buy/build one of these for a long white wall. Not necessarily looking for the shutter look, but just to break the eye up where a window should be. Thanks!
smokey847 is offline   Reply With Quote
Old 02-04-2012, 05:07 PM   #2
Rewards Points: 1,578
Shutter is what I'd call it.
Perhaps, cabinet door depending on size?
bob22 is offline   Reply With Quote
Old 02-04-2012, 05:19 PM   #3
Cannon port!
Hardway is offline   Reply With Quote
Old 02-04-2012, 05:30 PM   #4
Rewards Points: 13,458
I agree shutters is what I would google.
Simple to make, and far cheaper then buying them.
Old 02-05-2012, 01:56 PM   #5
Rewards Points: 308
Great. Finally found some images of what I am looking for.
Here is the sparse white wall I would like to do this on. The main house has black shutters, so I want to stick pretty closely to the look of the above picture. Any recommendations or tips of framing it out to appear it is a window frame?
I am probably going to look for shutters that will arch at the top to give it that carriage house look. Thanks for the recommendations!
Old 02-05-2012, 08:17 PM   #6
JOATMON
ddawg16's Avatar
Rewards Points: 1,454
They are called storm shutters.....in the old days, people would actually close them to protect the windows.
You can buy them at HD or Lowes.
Old 04-22-2012, 03:40 PM   #7
I understand the problem. Long areas of blank wall look wrong. Wrong, wrong, wrong.
I am going to suggest some additional solutions. 1) A big tall bush 2) a trellis with vines, roses or an espaliered fruit tree or something along the line of a 4) tresllisted arbor, with a park bench or swing underneath it.
The shutter isn't a bad idea, I am just offering alternatives.
Its hard to tell from the limited area shown, but you could make that area a nice little hidden quite spot with the trellis, the bench and some bushes concealing that area from the drive. People naturally like quiet corners and hedged in areas that offer seclusion while breaking up the open areas of the yard. Just like you don't want a big blank wall, be careful of big blank yards.
homesower is offline   Reply With Quote
Old 04-22-2012, 05:44 PM   #8
Rewards Points: 502
[quote=smokey847;844236]Looking to buy/build one of these for a long white wall. Not necessarily looking for the shutter look, but just to break the eye up where a window should be. Thanks!
/quote]
Never mind the wooden bit. What's the brick bond called?
tony.g is offline   Reply With Quote
Old 04-22-2012, 07:02 PM   #9
"Never mind the wooden bit. What's the brick bond called?"
running bond? Not sure what the question refers to?
Old 04-23-2012, 06:35 AM   #10
Rewards Points: 502
Just curious as to what the bond might be called, as the perpends all seem offset from the centre of the brick immediately below, which is unusual. Was wondering if anyone knew if there was a special name for it.
Old 04-23-2012, 07:39 AM   #11
Crusty Old Dude
Big Stud's Avatar
Could you find a starving artist to do a faux shutter job for you?
All the best to you and yours, Tom
Big Stud is offline   Reply With Quote
Old 04-23-2012, 10:36 AM   #12
Ole Wood Worker
BigJim's Avatar
Rewards Points: 302
Put brick mold on the wall and install shutters like the picture shows, or put a window in.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 04-23-2012, 08:24 PM   #13
Bond name
That is a stretcher bond, also known as a running bond. They modify if further based on the overlap, so this would be a 3/4 running bond.
Since it doesn't have any bricks running sideways to tie it into another layer of brick it suggests that it is just a veneer. There is usually a cavity between it and whatever it is anchored too, so it is also called a cavity wall.
Old 04-23-2012, 08:41 PM   #14
Looks like a residential version of a faux window. Faux windows are used in commercial construction to comply with ordinances that require a building facade to face a certain direction.
jmh2148 is offline   Reply With Quote
Old 04-24-2012, 08:06 PM   #15
Kinda looks like a Hay-Load Barn Door, the little door under the gable, above the big doors...
pucks101 is offline   Reply With Quote
When do I call the plumber? ctote Plumbing 4 07-07-2011 11:28 AM
Contractors Venting Thread. Long. Doc Holliday Off Topic 7 05-23-2011 09:18 AM
Call the Greene County Sheriffs Dept. Roofmaster417 Off Topic 0 04-29-2011 09:55 PM
What to do? Who to call? Dusty General DIY Discussions 1 06-07-2007 03:58 AM
