What Wood/product To Replace Rotted Door Jamb? - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-06-2009, 12:29 AM   #1
Rewards Points: 150
What wood/product to replace rotted door jamb?
I have two exterior doors that each have 4-6" of rot at the bottom of the door jamb. What product can I use that will hold up and not have me doing this same repair in 5 or so years?
It looks like the previous owners already replaced this before by cutting out the old section and putting in the same wood as a replacement. Well, the replacement is rotting out now.
Can I use something called Polywood? Just read a little bit about it online.
These doors have little coverage from the elements, so they will get water on them eventually. These wood jambs are soaking the water up and rotting to pieces.
ConstantChange is offline   Reply With Quote
Old 09-06-2009, 08:14 AM   #2
Household Handyman
Rewards Points: 1,408
At least in my area: Most standard size door jambs are available at the big box stores, ready to install. You will need to mortise in any needed hinges. I usually find it easier/quicker to replace the door jamb than to spend time removing/replacing a portion of the jamb for repair. One thing I do is to re-prime both sides of the jamb, with a high quality oil primer, and allow to thoroughly dry before attempting to install them. This may delay my project a day but I feel that it's worth it. You state that the door has little coverage from the elements. In a case like this I would suggest to the homeowner that they seriously consider the installation of a "storm" type door to keep the elements off of most of their nice door. Good Luck, David
Old 09-06-2009, 08:21 AM   #3
I have a similar issue with a bowed sill on a 42`` exterior door. I need to remove the sill and may have to replace the jamb so I did a bit of research. If you`re up for it and the doors themselves are still in good shape you might consider removing the entire door and replacing that side of the jamb top to bottom...Several local door manufacturers here have kits available for rebuilds.
I did splice in a foot long section on my jamb inside surrounding the deadbolt with 1 x 3 but it is not exposed to weather and I did not cut through the entire 1x 6 jamb.. I used 4- 6 inch screws and a bit of filler and all is good 5 years later, but again this is inside
Also see if you can do anything to deflect future moisture
Chemist1961 is offline   Reply With Quote
Old 09-07-2009, 11:05 AM   #4
Remodeling Contractor
yes, polywood or Minwax wood epoxy will work fine to patch the rotted wood.
Replace door sill = Need new door? NNJGUY Carpentry 23 09-01-2009 02:54 PM
one rotted deck joist to replace, need advice dougq Building & Construction 10 07-07-2009 03:18 PM
How to replace a partially rotted soffit that's sandwiched in pgraff99 Carpentry 21 10-22-2008 03:25 PM
Help: Rotted wall joists, wall frame plates, subfloor smallblockchevy Remodeling 8 07-22-2008 07:14 AM
Replace rotted 2x4's in cement patio KennS Building & Construction 3 06-19-2008 12:41 AM
